Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
2006 Denali XL - I changed the oil, started the car and the reduced engine power message came up. I pulled the codes - P1125 and P2138. Is this a throttle position sensor or a pedal position sensor issue?
I took a chance and purchased the accelerator pedal sensor assembly since it was in stock locally. I replaced it, cleared the codes, and have driven it several times. The light has stayed off. While I did not test the old pedal, it appears that it became defective.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
