Reduced engine power.......AGAIN!
03GMCYukonXL
2004 Tahoe Z71 fully optioned out.
Ok. long story short, I got the reduced engine power issue, and then I
Replaced the TPS wiring harness: Didn't work
Replaced the actual TPS: Didn't work
Replaced the throttle body: It worked! Been driving like a dream for about a year
Then, just today, the wife called me broken down on the side of the interstate with the reduced engine power and a P2135 and P0120 code. I'm assuming this is a different issue since the truck ran so good for a year. The P0120 code says it's the Throttle/Pedal position sensor A circuit. So can I just replace a sensor or should I try the whole pedal assembly? I have a spare Yukon in my bone yard for parts that has the same adjustable pedals. I'm just kind of down because I literally replaced then engine 6 years ago, and had the transmission rebuilt less than a year ago. I've heard this is a ground issue but I've painstakingly checked EVERY single ground and this thing is solid. No rust. All grounds are solid. I'm ready to sell it but I'm afraid because all the new cars are junk.
S33k3r
Dallas, Texas
This is most likely a wiring issue. But there is a sensor at the throttle, in the cab. Take a look at it and make sure it is fully snapped in place. But you probably should research those codes further, including Google searching for them, and maybe using some free AI cycles to help. Good luck!
According to Grok, using your own words:
P0120 (TP Sensor 1 Circuit) + P2135 (TP Sensor 1-2 Correlation) on a 2004 Tahoe with “Reduced Engine Power” points primarily at the throttle body side of the electronic throttle control (ETC) system, not the accelerator pedal.
These codes monitor the dual throttle position sensors (TPS1/TPS2) built into the electronic throttle body. The PCM/TAC sees out-of-range voltage on sensor 1 and/or the two sensors disagreeing. That triggers limp mode. Pedal-related codes are usually in the P212x/P2138 range. Your spare Yukon pedal assembly is unlikely to be the fix unless live data later proves otherwise.
This is a very common failure pattern on 2003–2006 GMT800 trucks/SUVs. GM even issued a bulletin (PIP3089B / Document ID 1869994) covering exactly these codes (P0120, P0220, P1516, P2135) on 2003–2006 Tahoes and related models. The usual root causes are:
  • Loose terminal crimps or broken copper strands inside the insulation within 1–4 inches of the throttle-body connector (outer insulation looks fine).
  • Poor connection at the throttle-body connector itself.
  • Failed internal TPS sensors in the throttle body (sensors are not separately serviceable on these units).
  • Less commonly, shared 5 V reference or ground issues (you already checked the obvious grounds).
Recommended troubleshooting order (do this before buying parts)​
  1. Scan-tool live data (key on, engine off or running)
    Graph or watch TP Sensor 1 and TP Sensor 2 voltages/angles while slowly sweeping the accelerator from closed to wide-open throttle (WOT) and back.
    • They should move smoothly and stay correlated (the scanner often shows a “TP 1/2 Agree” parameter).
    • Look for dropouts, spikes, flat spots, or one sensor that stops changing.
    • Wiggle the harness at the throttle-body connector and a few inches back while watching the data. If the values jump or the code sets, you have a wiring/connector problem.
  2. Physical inspection of the throttle-body harness (most common fix per the GM bulletin)
    • Unplug the 8-pin connector at the throttle body.
    • Inspect terminals for corrosion, bent pins, or looseness.
    • Gently tug each wire at the connector and 1–4 inches back. Feel for broken strands inside the insulation.
    • Perform a loaded voltage-drop test on the 5 V reference, low-reference/ground, and signal circuits if you have a good multimeter.
    • Repair with a quality pigtail (many aftermarket 8-pin throttle-body pigtails exist for these years) or new terminals/crimps. Do not just twist-and-tape.
  3. Clean the throttle body
    Carbon/build-up can sometimes contribute. Remove it, clean the bore and plate thoroughly with throttle-body cleaner (do not spray electronics), and reinstall with a new gasket if needed. Perform a throttle relearn afterward if required by your scanner.
  4. If data and wiring check out clean
    Replace the complete throttle-body assembly (TPS is integrated). Aftermarket or OEM units are widely available. After install, clear codes and perform the throttle-body relearn procedure (usually key-on engine-off pedal sweeps or a scanner command).
  5. Only then consider the pedal
    Monitor APP Sensor 1 and 2 live data the same way. If those look solid and the truck has adjustable pedals, a donor Yukon pedal is fine to try, but it is lower probability with pure P0120/P2135.
Additional notes​
  • You already verified grounds thoroughly—good. Still double-check G103/G104 (common on these trucks) with a voltage-drop test under load if the issue persists.
  • The TAC module (separate box on the driver’s side firewall area on many of these) is a distant possibility but rarely the first failure.
  • Intermittent issues often only appear when the harness is flexed or under heat/vibration, so the wiggle test while watching live data is critical.
  • After any repair, clear the codes, do a few drive cycles, and confirm the reduced-power message is gone.
Start with the live-data sweep + harness inspection at the throttle body—that resolves a large percentage of these exact codes without throwing parts. If you can post the TP1/TP2 voltage behavior (idle, mid-throttle, WOT) or photos of the connector, more specific guidance is possible.
03GMCYukonXL
03GMCYukonXL
Additional notes​
Thank you,
The problem is, I've already replaced the pigtail harness, AND the entire throttle body with a GM OEM unit. After I did that, the truck worked perfectly for almost a year. Not a single issue. It just randomly popped back up for no seeming reason.
Thank you,
You could walk through the troubleshooting procedure with a quality bi-directional scanner, as suggested, if you have not already done so.
03GMCYukonXL
03GMCYukonXL
I did the throttle body relearn procedure if that's what you mean.
03GMCYukonXL
03GMCYukonXL
I don't have one of those. I do have an HP Tuner though.
03GMCYukonXL
03GMCYukonXL
Well I changed the throttle body again, because the mechanic said that was likely the issue. Ran well, but today just sitting at the coffee shop idling, it did it again. And I shut it off and let it set for abut 5 minutes and it did well again until I let off the throttle to slow down to pull into my drive way and it did it again. I let it idle and the idle dropped more and more until it eventually died. This time I only got the P2135 code. I'm at a loss and ready to sell this vehicle that I've loved for so long.
LsHart
Senior Member
Did u say u replaced the pedal assembly? And if it's real bad now after the most recent throttle body then that tells me the quality of part is in question.
Fless
Moderator
People's Republic of Colorado
I'd be looking at the connections at the TAC module, or the module itself. Do you have a good bidirectional scanner you can use to look at the live data?
Here's the diagnostic path for P2135; I'm sure that you've done some of this but it might benefit a second look.
03GMCYukonXL
03GMCYukonXL
It was an oem unit. Ran phenomenal for a few weeks and I have not replaced anything on the pedal yet.
03GMCYukonXL
03GMCYukonXL
I did not personally but the mechanics likely did.
S33k3r
Dallas, Texas
When's the last time you changed the air filter? Have you taken a look at the MAF and/or cleaned it?
03GMCYukonXL
03GMCYukonXL
I have looked at the air filter and replaced it, not the MAF. Would a dirty MAF cause this issue?
Meathead16
A dirty MAF throws off how much air the computer thinks is entering the engine, in turn throwing off your fuel injector duty cycle, ignition timing, etc.
Basically everything that makes the engine run.
I've heard anecdotally that pedal and throttle body assemblies/sensors should be replaced together. That they 'speak' a certain type of language with eachother and replacing one without replacing the other males them incompatible to a degree. It wasn't specified but I'm assuming both would need to be oem and have any relearn/calibration done together.
alexblagoev
