2015 Yukon Denali XL Mag Suspension
I replaced my rear shocks yesterday with some Luft Meister. Install went great and easy until i started to plug up the connector. the wires pulled out of the connector of the shock. I installed them back in the holes of the connector and made sure inside the connector i could see the wires tips. But since i wasn't pay attention when it pulled out im not sure if the wires are in the right holes. Does it matter if the wires are backwards as long they make a connection. NOTE: Before i started the install i disconnected the positive terminal only because it was easy to get to. Should i have disconnected the negative cable instead or does that matter as well.
