Rear/driver side turn/brake light
RUFUS-05
Good afternoon everyone! I got into the 'Hoe after work today and eventually turned on the left turn signal and it was flashing fast... So I had no turn signal or brake light... I just got home and took the whole tail lamp assembly apart to change the bulb, but it wasn't blown. I checked the electrical connector with a tester and I have power to that but once I plug it back into the tail lamp assembly, I still have no turn/brake light. So, if you guys understood what I just rambled on about, would you think I need a new tail light assembly??? Thank you!
718frankb
LOCAL 282 TEAMSTERS
BROOKLYN,NY
the circuit boards on the tail lights are known to go bad.test it with new bulbs installed with a 12v tester -sounds like a bad board
Woned2004
