Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
Yea I get depressed looking at traffic/cams before I leave everyday...I have about 60mile commute lately. There is no clear way to get home so I just take the same ****** way and some days are better than others. Other way is turnpike which is getting to be $$$ about 10 bux a day I won't get reimbursed for. And if 95 is messed up everyone jumps on it and it's just as slow
randeez
randeez
south florida
:lol: nah
They want a few hundred miles of break in, been trying to get the tune close enough to drive for that atleast.
Want to get to get that in and then take somewhere and atleast find the upper end of what this whole set up will do. I think itll run out of turbo before fuel - certainly if I drop ethanol down to 50-60% it will.
Also its been parked for 3? Months maybe more with e85 in the tank, still showing as 75% e content lol. I doubt it was much better when it went in
need to get after it in the morning and check for leaks, nothing under the hood amazingly - i was a little worried about the stainless tubing sealing up but all seam good. wasnt anything dumping on the ground but want to crawl under and get a better look at everything i touch anyway. need to check/set fuel pressure on the regulator - it wouldnt go above 44psi on the logs for the few short trips i did so makes me think thats where the crack pressure is.
mitchievu
