Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
pwtr02ss
Tennessee
"Meth bung"
Coming along nicely! Ac lines look great. I never thought about building them at home until I was looking at the blue things on yours. Never seen those before.
skirtless...I'll reserve opinion until I see it at ride height
randeez
randeez
south florida
Not even close,
sectioned out that chunk, melted it back together but has a couple pin hole leaks I need to fix.
Heated up the whole side that goes over the tire and caved it in so it would round the wheel well. Had to bend some metal at the c pillar that was forward to the side, grind down some self taping screws on some crap that was mounted behind the tail light into the space.
randeez
randeez
south florida
I ordered some 1-1/2" marine "thru hull" fittings to use to supply the pump thru the floor, that will be mounted underneath. Going back into the tank I didn't want to go right next to the supply so I need to figure out how to dump the other hose back in up higher or in the front
