Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
Yes , no?
Having a hell of a time getting this fuel y fitting somewhere, out of the way, short to the rails, not hit the firewall, etc. I am going to just put the large feed hose onto it tight throw it down behind engine and I can get to the fuel rail fittings to tighten with intake in place. Making it up symmetrical it takes up way too much space and has to be high with over 90* bends to get it to the rails
And a couple of poser pics, cause I have to redo all of it anyway but needed some motivation
picture makes it look like its going down hill, which it may be a hair but the right side is actually closer so it makes it look much worse lol, i worry about shit thatll never be scene way too much
20210423_183610.jpg 20210421_193841.jpg 20210421_193832.jpg 20210421_193824.jpg
Sam Harris
Texas
Yes , no?
View attachment 277432 View attachment 277433 View attachment 277434 View attachment 277435
Glorious!!!
Yes , no?
:leghump:
randeez
randeez
south florida
Holy crap am I glad to have this thing mounted. Half of it atleast, going to build the other side to something, maybe forward to the core support. But trying to hold the pipes and line them up to cut, and the turbo is twirling around on the engine hoist. I couldn't run the pipe out any further, while it clears the turbo exhaust housing, it doesn't clear the cnc'd mount
20210424_165136.jpg 20210424_165144.jpg 20210424_182041.jpg 20210424_182049.jpg 20210424_182658.jpg
randeez
randeez
south florida
Not quite centered in the opening, buts as close as I could make it abd still be able to make up the pipe from the compressor to throttle body.
And is less than a 1/2" from the core support.. should be able to make shroud to seal the intake from the engine bay for maximum cold air age
20210424_182915.jpg 20210424_182911.jpg 20210424_182722.jpg 20210424_182706.jpg 20210424_182659.jpg
View attachment 277479 View attachment 277480 View attachment 277481 View attachment 277482 View attachment 277483
Excuse me radiator, I need to see out the front lmao. Awesomeness right there. That thing is fkn huge.
randeez
randeez
south florida
and since nothing is ever "completed" going to route the ac lines a little different.
1st - the line from the compressor to the condenser has a pretty nice gouge in it on the rubber hose, just going to replace it because its pretty good, which it had some more length in it but itll do. 2nd - the one from the condenser to the cabin im going to run straight out from the tee and send it back kinda of by the horn on the left side looking at the pic above, if that makes sense.
mitchievu
