Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Yes, I have the Fumoto drain valve on 3 of my vehicles.
The oil drains a little slower, but there is very little mess.
No guessing where to place your oil pan to drain in.
You can drain the oil and change oil the filter at the same time.
I just ordered a Femco; looks like a better solution to me but it's a bit more expensive and requires it's own adapter that snaps on with an attached hose. I'll try to post up results when I install it.
I've seen a fe where the check valve looses tension and starts leaking. Not to the point where it drains all your oil but enough to to make mess where you park.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
