Question regarding working tire size with 3/5 drop
tborders2016
Is there anyone that is running 285/45r22s 20 x 9.0 rim with a 3/5 drop that isn’t rubbing or bottoming out in the front running this tire size. I ask because I asked before and others said they had no issues with rubbing Thanks in Advance m
Fless
Moderator
People's Republic of Colorado
This seems like it could be related to your other thread since your drop:
Might be good to keep the related issues in one thread so members get the whole story.
kbuskill
NE. FL.
I used to run 285/40/22s on a 4/6 drop without issue but I did do the Norcal SS mod to the front wheel wells and rolled the fender lip to some extent with a pipe.
I then changed to 305/40/22s and that was terrible so I lifted it back up to a 2/4 drop until I wore out the Michelins.
Then I went with 275/45/22 Michelins and dropped it back down to a 4/6 but then I went to air ride so if I did rub I would just air it up a little... lol
T
tborders2016
What does the norcal as mod consist of? I did free air travel
kbuskill
NE. FL.
There should be a thread around here about it somewhere.
Basically you pull the plastic fender liner away at the lower rear and massage the metal back and then push the plastic liner back against it and secure it.
Charli1964
