PS Pump Leak
FrankH
I've a PS fluid leak coming from around the shaft of the linkage. This looks like a failed shaft o-ring to me and I'm wondering if it is repairable or if I need to purchase a new pump. See the attached picture. First time posting so hopefully the attachemnt comes through.
Thanks for the help!
Frank
livingez_123
Sandy, OR
Pull the pitman arm, remove the old seal, clean, replace new seal, replace pitman arm.
F
FrankH
Sounds easy enough. I'm assuming that with the pitman arm off that I will have easy access to the seal - correct or not? It looks to me like the box needs to come out and be disassembled to replace the shaft seal. Probably not too difficult but likely a few hours and a good seal kit would do the trick. It would help to know what I'm going to find in there if i need to disassemble it, however. I'm looking for a decent video on Youtube. Any suggestions?
RayBeau
