Pre-winter checkup on my 2014 Tahoe — input welcome
iboughtatahoe23
Hey everyone, doing some pre-winter looking-over on my 2014 Tahoe 4x4 (about to hit 190k) and wanted to run my list by you guys.
On the list:
- Swapping the front tires left to right to chase a slight pull to the right (alignment is fresh and in spec, pressures are even across all four)
- Front and rear diff fluid change
- Transfer case fluid change with Auto-Trak II
One thing I've noticed while driving it: in AUTO 4WD I get a groaning/binding noise on sharper turns on dry pavement. Quiet in 2HI, 4HI works like it should. From what I understand AUTO should act like 2WD on dry pavement, so I'm hoping the transfer case fluid takes care of it.
Also planning to measure tread depth on all four while the wheels are off, in case a circumference mismatch is tricking the system into engaging.
Anything I'm missing for winter prep? Anything else worth checking while I'm under there?
BeenChevy
Minnesota
Don't forget to do the brakes. Maybe the pull could be a caliper pin or dragging piston or old fluid.
Auto 4WD shouldn't engage until slip is detected so likely the hub sensors would be another thing to pull and clean.. Might have a wheel bearing starting to go. Also don't forget about the parking brake shoes.. Sometimes they wear out or drag and cause a slight pull also.
iboughtatahoe23
iboughtatahoe23
Good call on the brakes, gonna check the caliper pins and pistons when I get the wheels off and feel for a hot wheel after a drive. Parking brake cables too. Not totally sold on the hub sensors being the auto 4wd thing but I'll look at em while I'm in there. Appreciate the input
2011burbLTZ
Do all your fluids, no one wants to go an oil change when its freezing outside this includes your brake fluid if you haven't in 4-5 years. I also just fluid filmed my entire frame on my 2011, new trans pan with drain plug/filter/filter seal and maxlife fluid. Then drained and did the same in the transfer case with maxlife. Yesterday I did my first oil change (132k on the car and we picked it up this past winter) as I don't trust ppl/dealers. Oil life said 40% but hot it had 18-20psi oil pressure and 30psi giving it throttle but cold start was 40psi. I just did filter and 5w40 and cold oil pressure is up 5-10psi from first start. I would also check to make sure your accessory belt and stuff is good as well, PS fluid topped off, coolant is topped off and checks out.
On the list:
Alignment can be adjusted for any slight pull even if it is in "spec"
you do not mention what other maintenance has been done and when, so.....
I would do anything now that you won't want to do in the rain when it's 20 degree's out in the mud on the side of the road.
JoeBlobs
Senior Member
NJ
Here is what I wish I did before this last winter:
Check your front end suspension, especially ball joints and inner and outter tie rods. Mine wasn't great before winter, decided to send it, and ended up chewing through new tires because there was no way I was fixing it in freezing temps. If the ones you have now are greaseable, grease em.
Also since we're mentioning freezing temps, coolant could be an option if you're unsure of the service history. Simultaneously checking for leaks in lines and in the cabin for heater core leaks.
iboughtatahoe23
iboughtatahoe23
Hey everyone, been a while! Got caught up moving into a new place, but the good news is I’ve finally got a (small) garage to work in now, so I’m getting back around to the Tahoe.
Appreciate everyone’s input. Just to give a little more background, the inner tie rods have been replaced, the outer tie rods are older but have been greased, and the front shocks/struts are fairly new. Ball joints haven’t been replaced, and I’m really not looking forward to tackling those lol.
Last I checked, the tires were wearing evenly, although that was a couple years ago, so they’re due for another inspection.
As far as the rightward pull, Les Schwab aligned it back in March and checked it again in April. Everything is within spec, but one of the camber/caster eccentric bolts is seized, so they couldn’t dial everything in exactly where they wanted. The pull is pretty constant, regardless of braking or acceleration. I’m always making slight steering corrections to keep it tracking straight.
I’m planning to swap the front tires side-to-side, assuming they’re non-directional, to rule out tire conicity. While they’re off, I’ll check the brakes for drag, inspect the suspension and measure tread depth.
Still have the differential and transfer case fluid changes on my list as well.
@Doubeleive I see what you mean about correcting a pull even when alignment is technically within spec. Curious whether you think the cross-camber/caster differences could be contributing, or if you’d rule out the tires first.
Appreciate the help, guys!
it's free to rotate the tires yourself, I haven't ever had it make any difference but it's worth a try.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
You want a slight bit more caster on the right side compared to the left
iboughtatahoe23
iboughtatahoe23
Appreciate the input! Looking back at my April alignment sheet, my caster was actually +3.4° on the left and +3.7° on the right, so I’ve already got about 0.3° more positive caster on the passenger side.
Yesterday I swapped my two front tires left-to-right to see whether the pull would change. I also checked both front rotors for brake drag, and they felt pretty similar when spinning them by hand. Both tires have some outside-shoulder wear, slightly worse on the passenger side.
The road test was somewhat inconclusive because we had a steady 16 mph crosswind. That said, the Tahoe did seem to track a little straighter, and if anything, I noticed a slight gradual pull to the left instead of the right.
I’m not ready to draw conclusions yet. I want to drive it for another couple of days, preferably on a calmer day and a good stretch of highway, before deciding whether the tires were contributing to the original pull.
I’ll report back once I get a better feel for it!
donjetman
In Dec 2023 I rebuilt the frt end of our 07 Yukon and installed new tires. I've put 24k miles on it since then. I set the camber at +.5 degree both sides and set toes 1/16" toe in. Left the caster alone.
No pulling or undesirable tire wear.
iboughtatahoe23
iboughtatahoe23
Just to follow up on this thread it does seem like the pull switched to the other side now after swapping front wheels hmm but the tire wear looks nearly the same
BeenChevy
Minnesota
If you're pulling to one side, that's a problem. They couldn't dial in your alignment due to a seized bolt? Or they couldn't loosen the nut on you A-arm?.. Did they give you a printout? If the brakes are seizing, you'll smell and feel that. Dragging pads can leave a coasting rotor too hot to touch. Let us know what you find after doing the brakes.
iboughtatahoe23
iboughtatahoe23
Yes, they gave me printouts, and I’ve compared the March and April readings. The issue was a seized eccentric adjustment bolt. They weren’t willing to force it and risk damaging the upper control arm or surrounding hardware.
On March 7, they corrected my total front toe from +0.35° to +0.09°, but camber and caster remained unchanged. My April readings showed +0.1° left camber and +0.4° right camber, with +3.4° left caster and +3.7° right caster.
I also recently inspected both front brakes while swapping the front tires left-to-right. Both rotors had very similar resistance when spun by hand, with no obvious severe binding. After the tire swap, the rightward pull seemed to improve, possibly even becoming a slight leftward pull. Unfortunately, it was pretty windy during the test, so I’m still evaluating it.
I don’t necessarily think Les Schwab did anything wrong by refusing to force a seized adjustment. I’d rather address the hardware properly than damage something trying to get the numbers perfect.
iboughtatahoe23
iboughtatahoe23
That's why I'm a DIYer. Nobody to blame but myself.
I’m all for DIY work, which is why I do plenty of my own maintenance and repairs. But there’s a difference between working on your own vehicle and having access to a professional alignment rack.
I’m not exactly going to run out and buy alignment equipment because a shop encountered a seized eccentric bolt. Part of being a DIYer is knowing which jobs make sense to tackle yourself and which ones require specialized equipment
alexblagoev
