Hello,
I need some help finding parts for the power seat (drivers side) for my 2007 Denali.
There are two electric motors- one that lifts/lowers the rear of the seat and one that lifts/lowers the front. The front was not moving and I took the cushion off and it appears that the gears inside the little black "differential" that turns the screw to raise & lower the front are bad. The motor is turning the flexible shaft but inside the little differential I hear noises and the screw thing is not turning.
Does anyone have a parts list or parts diagram I can see the names of the parts I need to order? Also, any ideas on where to order them from (other than the local dealer)?
Thank you,
Dan
Thank you,
Dan
