Please help 07 GMC Yukon Denali mystery
Leequiz
I need to know what the part circled is and if it not being connected would cause a really rough low idle. My truck did just that and when I opened hood this was just hanging. 07 Yukon Denali xl 6.0 Thank you
L
Leequiz
Btw it is on top of the ( looking at truck) right side top of shock housing next to and lower than fuse box
Jimmyy
Minnesota
You'll have better luck with a reply if this was in the correct section. Your in the 2021+ section.
Seamus
Palm Beach
That looks like the top of the shock up front?? I had a 2013. That would be the connection to your autoride shock. Has nothing to do with motor, just the ride.
donjetman
you sould have a 6.2 liter engine, and that is an electrical connection on your shock for autoride, nothing to do with your engine.
Is there a wire connected to the top of the shock on the other side?
After powersquinting, I see that that's the harness connector to your AutoRide shock. This would have absolutely no affect on the idle. Have an engine light on? You should at least have a "Service Suspension System" message. That connector being unplugged would make that shock soft. If the others are connected and the system is otherwise operable, that'd make for some squirrelly handling.
willie110hh
