Phantom Rear Window Activity
Plimbob
Des Moines Iowa
After my 2017 Tahoe sat out in the sun last Saturday (98 degrees) the rear drivers side window all of a sudden would go down on it's own. I'd roll in back up and it will go back down, I put the window locks on and it stopped but when you take the locks off it goes right back down. I suspect it's something wonky with the BCM.
I looked thru past threads and didn't see anything pertaining to this. I was going to unhook the negative battery cable and let it sit for 30 minutes and see if it will reset the window?
Anyone have this happen?
Big Mama
Virginia
That’s a weird one. What happens if you disconnect the window switch?
P
Plimbob
Des Moines Iowa
I haven't attempted to disconnect the switch yet. I was going to disconnect the battery for a bit and see if it reset properly. If that doesn't work, the on to option 2-3, etc.
DefiantOne
