PCV system affects transmission and ride?!
Kobot
I have a ‘19 Tahoe with the L86 and 10L80. Had it over 3 years now. I installed a Corsa intake and exhaust about two years ago. The truck is stock otherwise besides an AFM disabler.
Recently I started to notice the idle was a little rougher than usual. Not terrible but noticeable to someone that pays attention to their vehicle. I figured it was time to clean the air filter and may as well clean the MAF and throttle body while I’m at it. While doing so, I noticed the Corsa supplied PCV hoses had ever so slightly expanded at the ends that connect to the valve covers allowing them to easily slide off. I cleaned everything up and installed hose clamps on the hoses and to my surprise, throttle tip-in and part throttle acceleration have noticeably smoothed out. Induction and exhaust sound also sound slightly more refined now.
The loose hoses must have been allowing unmetered air in. I was surprised because I didn’t know I had an intake leak in the first place! Throttle tip-in before the fix felt a little touchy at low speeds but I have a lead foot and it never alarmed me. I assumed it was due to the intake but now I see there was an issue. Never had any lights or any other drivability issues.
Here’s the part that really surprised me. The 1-2, 2-1 and 2-3, 3-2 shifts are noticeable smoother also! I’m looking for a knowledgeable explanation of how. I assume it has to due with the unmetered air affecting fuel trims and torque management calculations with the ECM. The idle at the exhaust and at the engine with the hood up sound perfectly smooth but still feels like it could be smoother from the feel in the seat so I need to check the plugs.
Here’s another unintended side effect that could possibly be placebo but I’m not sure. The ride feels smoother! I replaced the OEM mag ride dampers about a year and a half ago so the ride has been fine but it really does feel smoother now. Is Magnaride affected by the ECM?
If you have a Corsa intake, check your PCV hoses.
Knowledgeable and technical explanations are welcome!
I asked Grok about your issue, using your exact post, and this was the response.
Your diagnosis is correct. The slightly expanded Corsa PCV hose ends were allowing unmetered air (a vacuum leak downstream of the MAF) into the intake tract. That explains the milder rough idle, the “touchy” tip-in, and the measurable improvement once the leak was sealed with clamps. No DTCs or obvious drivability complaints is common with a small leak—the ECM just compensates via fuel trims until the leak becomes large enough to set a code or cause misfires.
Why the 1-2, 2-1, 2-3, and 3-2 shifts improved​
The 10L80 is a highly coordinated, torque-managed transmission. The ECM and TCM constantly exchange data over the CAN bus. During a shift the TCM requests a precise, temporary reduction in engine torque so the oncoming and off-going clutches can swap load smoothly without flare, bind, or a hard “clunk.” The ECM delivers that reduction primarily by retarding spark (and sometimes cutting fuel or adjusting throttle). The accuracy of the torque reduction depends on the ECM knowing the true engine torque at that instant.
Engine torque is not measured directly; it is calculated from:
  • Air mass (MAF reading + modeled volumetric efficiency)
  • Fuel delivery (injector pulse width, commanded by short- and long-term fuel trims)
  • Spark advance
  • Other load factors (AFM/DFM state, accessory loads, etc.)
When unmetered air is entering after the MAF:
  • The actual air charge is higher than the MAF reports.
  • The engine runs leaner than the ECM initially calculates.
  • Closed-loop fuel control adds positive fuel trims to restore stoichiometry.
  • The calculated (virtual) torque the ECM reports to the TCM is therefore wrong—usually lower than actual torque, or at least less consistent under changing load and RPM.
With incorrect torque information the TCM’s pressure and timing commands for the clutch packs are slightly off, and the ECM’s torque-management spark retard is applied on a less accurate baseline. The result is the subtle roughness or “touchiness” you felt on the low-speed upshifts and the corresponding downshifts. Once the leak is sealed:
  • MAF reading matches actual air mass again.
  • Fuel trims return closer to zero / more stable.
  • Calculated torque becomes accurate.
  • Torque-management interventions and clutch pressure ramps line up properly.
That is why the improvement showed up specifically on the 1-2 / 2-3 family of shifts (the ones that occur under light-to-moderate load where a small air-mass error has the biggest relative effect). Larger throttle openings or higher gears tend to mask the same percentage error.
Idle feel and plugs​
Even with the hoses clamped, a residual “seat-of-the-pants” roughness at idle is worth investigating with plugs. On an L86 that has been running AFM (even with a disabler) the plugs can show uneven wear or light carboning on the deactivated cylinders. A small remaining vacuum leak, slightly fouled plugs, or a weak coil will still be felt more in the seat than heard at the exhaust tip. Checking/replacing the plugs and verifying that fuel trims are now close to zero at idle and light cruise is the logical next step.
Ride quality / MagneRide​
MagneRide dampers are controlled by their own electronic suspension control module. It primarily uses wheel-acceleration sensors, body-acceleration sensors, and (on some calibrations) vehicle speed and steering angle. It does not take a direct “engine torque” or “fuel-trim” input the way the TCM does. However, two secondary effects can make the ride feel smoother after an intake-side fix:
  1. Engine torque delivery is now more linear and free of the small torque “blips” or inconsistencies that a vacuum leak + compensating fuel trims can produce. Those micro-variations are transmitted through the driveline and body and can be perceived as a less refined ride.
  2. With smoother tip-in and cleaner shifts, the overall NVH (noise, vibration, harshness) level drops, so the same damper settings feel more compliant.
It is unlikely that the MagneRide control algorithms themselves changed their damping maps because of the fixed leak, but the reduced driveline and engine-induced vibration makes the existing damping feel better. Pure placebo is possible, but a real secondary effect from cleaner torque delivery is also plausible.
Bottom line and recommendation​
Sealing the unmetered-air path restored accurate air-mass measurement → accurate fuel delivery → accurate calculated torque → properly coordinated torque management and clutch control. That is exactly why the shifts cleaned up. The same accuracy improvement explains the refined induction/exhaust note and the smoother tip-in.
Keep an eye on the fuel trims (STFT/LTFT) with a scan tool for a few drive cycles; they should now be well-behaved. If the residual idle roughness remains after the plugs are addressed, a smoke test of the rest of the intake tract (including the Corsa airbox and any other PCV or vacuum lines) would be the next logical check. Good catch on the Corsa hoses—those soft ends expanding over time is a known weak point on several aftermarket intake kits.
the maf and throttle body play a bigger factor, especially the maf, you might go one step further and clean the map sensor too. my experience is they are affecting the k2's more than they have with previous generations. I have had to replace the map sensor in both our 2016 & 2018, 1 straight up died and the other was giving random errors and causing driveability problems.
thatboy_eddie
