Paying for OnStar to get my supercruise..??
JKeller
You can turn off the automatic lane changes. Once you turn that off, it will maintain your lane or change lane only when you instruct it to with the turn signal. Sounds like that would have prevented your issue.
Padraig
Army
OK. Dumb question coming up. What is the attraction of Super Cruise? Not being a smart ass, really want to know.
Padraig
QwikKotaTx
For me, no. I'd have been using it on open highways or on lower speed roads to get used to it, personally. BTW, if the truck behind you couldn't slow down in time when you put the brakes on, then it was probably following you too closely. That's not SC's fault (nor yours).
From what you described, it was working effectively. If you didn't take control of the vehicle when the wheel started flashing and the truck told you that SC was shutting off, then that's on you. It requires you to be paying attention to function.
It's not perfect, but it works pretty darn well.
The time when the brakes were heavily applied there was no one in front of us and the semi in the next lane never veered over. I was paying plenty of attention because I have never used self driving and don't fully trust it. Again, I'm not telling anyone what to do with their own vehicle. Just stating what I intend to do and the reason why.
QwikKotaTx
I assume you are referring to me. I have that turned off. I let it make a few lane changes by activating the turn signal manually. That had nothing to do with either condition I mentioned.
KMeloney
He was referring to Stbentoak whose wife thinks it changes lanes too often.
KMeloney
Padraig
You know what SC is/does, right?
I've used it on the I95 HOV lanes around DC, where there's little traffic, no tight turns, and you can just let the truck do the driving. I use it all the time on a little 2-lane roadway where the speed limit is 35mph and it's heavily policed. I've used it in stop-and-go highway traffic where the truck will slow to a complete stop when traffic in front has stopped (and then accelerate when traffic moves again). I've use it at night in an absolute downpour where I literally couldn't see the highway lanes nor the sides of the road -- but the truck could.
It can help keep you from becoming fatigued on a long trip and in stop-start traffic. It might allow you to take some bites of a sandwich while driving down the highway. It's useful in a variety of circumstances.
Stbentoak
The problem with this'cause if you are beyond your comfort level and can't see, but you think supercruise can, you can get yourself in a world of hurt pretty quickly. Because it doesn't understand conditions and won't slow down based on visibility. By the time it kicks itself out you could be going twice as fast as you need to be for current issues...
I'm not downing it I'm just saying that you should never let the vehicle drive faster than you would drive if you were in control based on conditions.....
Jus Cruisin
Senior Member
Metro Detroit
I don't use it on "two lanes" or surface streets if you use that term. There a lot of them in my Detroit metro area that have the "steering wheel" lit up. I don't need "help" with potential driver fatigue on the two lane roads. I use it immediately when I hop on the interstates/freeways. I have it set to auto lane change and there are times I will override it when I see it being temporary or even unnecessary. But, I won't buy another gm product without it.
KMeloney
Not sure if your response about SC going too fast was in response to something I wrote... I never let the truck drive faster than I would -- and you HAVE TO PAY ATTENTION in order for SC to function/stay functioning. You've got to set the speed, and you've got to be paying attention to the road, so I'm not really sure how someone would find himself in the situation you've described unless they just don't understand how SC works.
Stbentoak
You said in your statement:
That pretty much implies that you are driving too fast for conditions, and you are trusting Super Cruise to keep you in line because you can't visually see what's going on. You can pay all the attention you want but if you're having something drive for you in a condition that you're not comfortable with...... Then you are not in control....
KMeloney
Got it. No, not remotely close to the situation (I didn't imply anything regarding speed/going too fast for conditions). That would be moronic.
I set it for 10 mph and controlled the speed from the steering wheel, and it got me down a long access road/on-ramp to the highway and kept me in my lane until the rain subsided enough to be able to see road markings and whatnot. It was nighttime, I was the only one on the road, and SC was extremely useful in that particular scenario.
LEsoftballdad
Suffolk County, NY
Here's the beauty of SC, BC, or FSD. You don't need to use it. If you're doubtful about the technology, you probably shouldn't fly on an airliner, since the autopilot does 95% of the flying and can even land the plane. In fact, the first airliner with that capability was the Lockheed L-1011, which was designed in the late 1960s...
The problem is the mix of people who use it and those who don't. My assistant avoided rear-ending the car in front of her because the auto-braking on her Hyundai reacted faster than she could. The problem is that the guy two cars behind her rammed into the car directly behind her, causing his car to ram into hers.
KMeloney
Here's the beauty of SC, BC, or FSD. You don't need to use it. For those doubtful of the technology, you probably shouldn't fly on an airliner, as the autopilot does 95% of the flying, and it can even land the plane. In fact, the first airliner with that capability was the Lockheed L-1011, which was designed in the late 1960s...
The problem is the mix of people using it and not using it. My assistant avoided rear-ending the car in front of her because the auto braking on her Hyundai reacted faster than she could. The problem is the guy two cars behind her rammed into the car directly behind her causing his car to ram into hers.
Yeah, personally, I don't care whether anyone else uses it or not. I've only posted what I have regarding it to inform others about it (based on my experiences) and cut through some of the mis/disinformation some have posted.
That said, I'm no "pro" with it. I still have questions about aspects of it. I'll still toggle down the speed from the wheel if I think that the set speed is too high for an upcoming bend. I'll often take ahold of the wheel going around a left bend with a semi to the right of me (sometimes I feel like SC puts me too close to the right side of the lane going around left bends -- and I don't know what will happen if a truck drifts over closer to my lane)...
Mariam26A
