Passenger door doesn't unlock from driver side
sidthekid
Florida
My passenger side door on my 2 door 95 hoe only unlocks when you hit the unlock switch on the passenger side door or unlock it manually(The driver side switch won't unlock it). It was doing it intermittently at first. Now it doesn't work alltogether. My keyless entry doesn't work on the passenger side door anymore either.
Any suggestions??
drowndindreams
Unknown
get a new switch for your driver side door, then pull the passenger door panel off and see if any rods have been freed (most likely they have)
sidthekid
sidthekid
Florida
That doesn't explain why the keyless entry isnt working on that side....right???
drowndindreams
Unknown
your keyless entry unlocks only the driver door? get your key and unlock the passenger door from the outside. if it works, than your problem is most likely the security system itself, if it doesnt, that means that a clamp has been freed and your rods arent doing anything, if that be the case, you need to take a look inside.
Woned2004
