07hoeCHEVY
- Joined
- May 15, 2019
- Posts
- 14
- Reaction score
- 4
Has anyone encounter this code I have a 07 tahoe 4.8
Sent from my SM-N950U using Tapatalk
Camshaft position sensor circuit?Has anyone encounter this code I have a 07 tahoe 4.8
200+ miles just did front struts an rear shocks that is allCamshaft position sensor circuit?
I’ve read of various folks here having it.
There are a variety of reasons that you could have this code.
How many miles do you have on the vehicle?
Any recent work done on it?
Could just be a bad sensor or something more serious.
Gona try replacing the sensor it behind the starter correct.. ??? Not the one behind the harmonic balancer200+ miles just did front struts an rear shocks that is all
Well, if you have a good scan tool, like a Tech2, I would think you can see if the sensor is just not putting out the proper voltage or if the sensor is telling you you have bigger issues. At 200K+, you could have a timing chain that is stretched. I am not familiar with what the 4.8 has for a timing chain tensioner. I have also seen where the sensor gets messed up due to metal filings collecting on it and messing it up.200+ miles just did front struts an rear shocks that is all
Is that the only code you have? Are you by chance getting a crankshaft position code as well?
