James Ward
2015 Tahoe LT
I'm getting ready to have the fluid in my Transfer Case in my 2015 Tahoe LT changed or do it myself. What is the best ATF to use ? Thank You ahead of time.
Well thank you Swathdiver, Can you use a full Full Synthetic ATF in the transfer case, and do anyone know of a magnetic drain plug for the transfer case ? And the differentials get standard 70/90 gear lube, at lease for the front diff, but the rear diff needs 'Limited Slip' fluid. What is this posi-traction diff get in the way of lubrication ?
Dexron VI by ACDelco is today listed as Full Synthetic on the containers. So yes, use it. On my truck, the TC and front differential have magnetic drain plugs.
In the other post I listed what fluids go in the axles, they are different you do not need "posi-lube" if using the factory fluid. Aftermarket "may" be different.
