I'll add 2 basic, general points...
1-- The physical size of the filter's case isn't the important factor. The ability of the filtering mateial inside to trap particles of contaminant(s) is what matters. The smaller a piece that can be trapped (measured in 'microns') the cleaner the oil is kept.
2-- The breakdown of an oil's additives is at least as inportant, maybe more so, as the oil's cleanliness in determining how long the oil can stay effective.
joe
I understand...
As far as efficiency is concerned the M1 EP filters are 99% efficient at 30 microns. As far as filters go the M1 ranks up at the top with Purolater Pure 1, K&N, Wix (Napa gold). When compared with other filters these are considered the best according to the research I have done.
And as far as the additives are concerned I agree. That is why I use the 15K mile oil.
The other thing to mention here is that with the bigger filters and the aftermarket oil cooler I am running 2+ additional quarts of oil in the system. I say 2+ because I don't know for sure how much capacity was added since I pour my oil out of 5qt jugs it hard to get an accurate measure.
What I do know is that a quart of oil is 57.75ci and my 2 filters equal 131.10ci.
So 57.75 x 2 = 115.5
And 131.10 - 115.5 = 15.6ci
So the filters alone add almost an additional 2 quarts by themselves. I say almost because my filters capacity is 2 quarts plus that left over 15.6ci and the stock filters capacity is 28.21ci which leaves it 12.61ci shy of 2 full quarts. Now if you figure in the capacity of the oil lines to and from my filter setup and oil cooler and the capacity of the oil cooler itself it is probably somewhere in the 2.5-3 quart range over stock.
I know that two 5 quart jugs will top off the truck with a little left over in one of the jugs. I just never really paid any attention to how much was left. If I had to guess I would say maybe a little over a quart.
Anyway back to my point.
While the bigger size of the filter doesn't automatically mean that the filter has more filtering material inside what it does mean is that the filter (and cooler) adds more total capacity to the oil system which in my particular case is somewhere between 33%-50% more than the original capacity of 6qts.
So if we deduce that the factory 6qt capacity and it's associated amount of additives is good for X number of miles then by adding 33%-50% (2-3qts) more capacity and their additives then we should be able to figure that the OCI should be able to be safely extended out 33%-50% further.
If you think about the oil system as a circulatory system them by adding more oil to the system the "same" oil particles don't get circulated through as many times with the same engine run time which equals cooler, cleaner oil.
At some point I should send an oil sample out and have it analyzed to see how it fairs after 10k+ miles. I just hate to spend $30-$40 on it... lol... yes I am cheap sometimes.
Who knows... with an oil analysis perhaps it would reveal that I can extend it out even further... lol
