2002 Tahoe LT 5.3L Flex engine.
As I have stated a few times, I have not been in shops in about 10 years.
I had a small oil leak, before recent oil and filter change, that showed as a drip on the bottom of the old filter. It was on a rack when I was showed this and could not see any oil from the back of intake or the left valve cover. But there was a small amount of air blown smear just above the filter area. It does not have an oil cooler on this engine. I assumed there was an oil filter adapter seal leak. I bought a metal and rubber seal, as per application, but the tech at the garage where I had a bunch of recent work done said there is no oil filter adapter. I watched a you tube about this and it appears there is possibly an oil cooler block off plate on a 2005 5.3L engine in the video. When I look up at RA I find no listed seal/gasket for this block off plate and I also looked at GM Parts.
I think my small leak was just a leak at the oil filter seal, if in fact there is no block off plate and no oil filter adapter seal/gasket. Thanks in advance for any clarification.
It sucks that I don't have lift available to me after 35 years of having them.
