Agree with Scott above. The IFS is not good enough, no matter what you put up there. Custom a-arms, 1 ton ball joints, etc. It's expensive at first and a fair amount of technical detail is involved in the solid axle swap, but it's doable. It's becoming very common for people who don't do alot of work on cars to be able to safely do a SAS on their trucks. Off Road Design (ORD) makes nice kits that are almost bolt on for said SAS on our trucks. I do encourage you to build it once and build it right. For example, a Dana 44 (ford 77-79 years are easiest) is ok, a dana 60 is best. The dana 44 did come in a 3/4 ton pickup from ford, but for offroad, the dana 60 is the way to go for serious off road time, particularly in a fullsize rig like ours. The dana44 can use the hubs from an old chevy and you can keep your 6 lug wheels. otherwise the 1 ton gear is 8 lug unless you get custom machined hubs which aint had for less than at least $1k. I'm using a dana 44 as mentioned above with machined chevy hubs and I have a 6lug 14 bolt 9.5" rear end (the semi float axle) that I'm working on now for my truck. So I'll have 3/4 ton gear around me. Mine is not used for rocks or mud really, I just don't want the liability of a 10 bolt rear end (factory) and the IFS. I don't like doing bushings and ball joints every 30k miles with my 2 door tahoe's 37" tires.
NP241 transfer case is the way to go. Simple to work on, Slip yoke eliminators are had easily (jb conversions), and it's pretty beefy. Much better than the 246 or the autotrack case (I forget the number on it....)
After a ton of research, if you decide you want to go that way, start gathering parts. Read read read. pirate4x4 is a great resource for this kind of thing. there are some real a**holes there but they know their crap when it comes to wheeling hard. Read the 30-40 threads on SAS info and then reread them again. I found my dana 44 from a guy in Amarillo on Pirate and he charged me $400 for it. It's in good shape, should be fine for my daily driver that gets dirty sometimes. If I was building a less street-used truck, I'd have 1 ton gear at front and back. I may do that anyway if I decide that the d44 isn't enough.
Keep us posted and good luck.
