noob engine swap questions
rxphiler
Charleston, SC
hey I have or will be getting a 1998 tahoe with a bad engine. What are the engine swap options I have that are not a huge PITA. Oh yeah it is a 1998 4dr 4x4.
thanks
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
Just drop in a stock 350 Vortec engine. It will bolt right up and is all plug and play. There are other options out there, but they are more complicated and complex, so the easiest would just be going back to stock. What's wrong with the engine in it now? And would you be going with a reman'ed long block or a used engine?
rxphiler
rxphiler
Charleston, SC
I just have a chance to get a cheap tahoe. The car lot it is at states it has an engine knock and needs to be replaced. If replacement is the issue I am planning on putting a stock tahoe engine it but I didnt know what issues I would have if I found a new engine with low miles.
95TwinTT
Minnesota
Why not just repair the engine that's in there? A knock is not a death sentence.
While you are in there, you could make some mild improvments, like cam, etc. :)
rxphiler
rxphiler
Charleston, SC
I just wanted the cheapest easiest swap or fix. Not looking for any performance gains. Just wanted something to haul stuff in and use as my beach car. I proly will get it and look at getting whats wrong fixed if it is cheaper than swapping out the engine. I just not that familar with the domestics and wasnt sure what could be done. Thanks for the suggestions.
96ProCompTahoe
IN
how cheap is cheap?
rebuild it with some better parts, get another 200K outa it.
bowtiefreak
No Quarter
Near Philly
You can get a new motor on the cheap. I think a rebuild is your best option and tweak it a bit to bring it to life.
Woned2004
