non level parking
nomech
When parking anywhere that isn't level/flat, is it recommended to hold down the brake as you shift to park then engage the parking brake and the let go of the brake pedal? I'm reading the pros and cons to doing this. The obvious con is that, even on a slight decline/incline, there is a lot of force on the transmission/etc.
I have a 25 HC and sometimes when I reverse/pull out of a slight decline/incline, the vehicle doesn't move when I go to drive, I have to tap on the gas, lightly, and I hear the mechanical parking brake release (I assume that's the parking break) but I don't always hear this (something must trigger it) and I don't manually engage the parking brake when I park.
What are your thoughts on this? Is the vehicle automatically doing this and I just don't realize it?
I'll start paying more attention, but I don't think I notice a roll back or forward when I put it in park and take my foot off of the brake.
The only vehicle where I've ever used the parking brake was when it was a manual, I would park, put the vehicle in 1st gear and set the parking brake.
2024 White Tahoe
I have always set the parking brake with the brake pedal applied, then shifted the transmission to park.
My 2024 Tahoe Premier 4WD will set the parking brake automatically when I stop on an incline, when I shift to park. However, the parking brake will not release if I push the release button (with my foot on the brake pedal) with the engine running. I must shift to reverse or drive for the parking brake to release (with my foot on the brake pedal). It is irritating. This is probably what you are describing in your post?
When I’m on level ground, the parking brake does not apply automatically. I can set and release it by pushing the release button.
I always set the parking brake. I live in a hilly area, with many driveways and parking lots that have inclines.
Some GM vehicles will randomly apply the electronic parking brake if the driver does not use the parking brake. My 2014 Impala 2LTZ has that feature. I can’t recall if my Tahoe does, but I always use the parking brake (except when driving in snow and ice, is sub-freezing temperatures).
It is a good idea to use the parking brake as it keeps the mechanical parts from freezing in place.
N
nomech
I must be referring to the electronic parking brake, I thought the electronic brake and the push button (I think it is a push button I need to check) were the same thing. In a hilly area I would understand, but I'm talking about an average driveway or a parking lot with a slight incline/decline (depending on if you reverse in/out). I'm not saying those don't matter, I think anything that isn't flat would be worth setting the parking brake if that's what people recommend to save any components in their vehicle. I guess even on a flat surface it doesn't hurt to set the parking brake, but I don't think things can really 'lock up' on a flat surface since the vehicle is free to move in any direction where there's momentum.
Javelina
Pleasanton, CA
I have always used the following sequence, hill or no hill:
To Park:
1.Foot on brake pedal
2.Shift to N
3.Apply parking brake
4.Foot off brake pedal
5.Shift to P
6.Engine off
To Go:
2.Start engine
3.Shift to N
4.Release parking brake
5.Shift into gear
6.Foot off of brake pedal
This allows the weight of the vehicle to be borne by the brakes. My belief is it reduces wear & tear on the transmission parking pawl.
I find the electronically operated parking brakes clumsy to use while performing the above sequences. A mechanical parking brake handle/lever made this rather instinctive.
N
nomech
To Park:
2.Shift to N
5.Shift to P
6.Engine off
To Go:
2.Start engine
3.Shift to N
5.Shift into gear
I don't think my 25 has a handle, I believe it is only the push button. Which means, do I only have electronic parking brake regardless if I engage or if the vehicle does it on its own? Of course my experience is that the vehicle doesn't always engage the parking brake. I'm going to check the manual.
From the manual
The Electric Parking Brake (EPB) can be applied
when the vehicle is off. If there is not enough
electrical power, the EPB cannot be applied or
released. To prevent draining the battery, avoid
unnecessary repeated cycles of the EPB.
The system has a red EPB status light and
an amber service EPB warning light. See
Electric Parking Brake Light 3 112 and Service
Electric Parking Brake Light 3 112. There are
also parking brake-related Driver Information
Center (DIC) messages.
Before leaving the vehicle, check the red EPB
status light to ensure that the EPB is applied.
If a message displays on the DIC indicating the
transmission is unable to shift soon, the service
electric parking brake is on, and the EPB light
flashes at the same time, the system must be
reset. Start the vehicle, apply the EPB, and then
release it. The message and the light should
turn off. See Electric Parking Brake Light 3 112
and Service Electric Parking Brake Light 3 112.
EPB Apply
To apply the EPB:
1. Be sure the vehicle is at a complete stop.
2. Press the EPB switch.
The red EPB status light will flash and then
stay on once the EPB is fully applied. If the
red EPB status light flashes continuously, then
the EPB is only partially applied or there is
a problem with the EPB. A DIC message will
display. Release the EPB and try to apply it
again. If the light does not come on, or keeps
flashing, have the vehicle serviced. Do not drive
the vehicle if the red EPB light is flashing. See
your dealer.
If the amber service EPB warning light is on,
press the EPB switch. Continue to hold the
switch until the red EPB status light remains on.
If the amber service EPB warning light is on, see
your dealer.
If the EPB is applied while the vehicle is
moving, the vehicle will decelerate as long
as the switch is pressed. If the switch is pressed
until the vehicle comes to a stop, the EPB will
remain applied.
The vehicle may automatically apply the
EPB in some situations when the vehicle is
not moving. This is normal, and is done to
periodically check the correct operation of the
EPB system, or as required by other safety
functions that utilize the EPB.
If the EPB fails to apply, block the rear wheels to
prevent vehicle movement.
EPB Release
To release the EPB:
1. Turn the ignition on or to accessory mode.
2. Apply and hold the brake pedal.
3. Press the EPB switch momentarily.
The EPB is released when the red EPB status
light is off.
release the EPB by pressing and holding the EPB
switch. Continue to hold the switch until the red
EPB status light is off. If either light stays on
after release is attempted, see your dealer.
Automatic EPB Release
The EPB automatically releases if the vehicle
is running, placed into gear, and an attempt is
made to drive. Avoid rapid acceleration when
the EPB is applied to preserve parking brake
lining life.
Interesting discussion. I've never used a parking brake on any automatic transmission vehicle that I've ever owned. Not saying that I'm right, just saying that I've never used one.
N
nomech
I agree, interesting. I see both sides of it. On one hand, I'd like to think that manufacturers have thought of this and that force of metal/gears/etc while the car is parked and not on a level surface is not causing damage and was designed that way, but I can see how the opposite of that thought is also true/valid.
Then you look at all the vehicles that are parked on non level surfaces and that the majority are NOT engaging the parking brake and those cars are 'fine' as far as we know. Many of us on here might not fall into that category because we took the time to register on a car forum and ask/read about these scenarios, but we are not the norm. The majority of people put their car in park and move on with their day.
Javelina
Pleasanton, CA
The "BOING" sound when shifting into D from P is cringe worthy when the weight of the vehicle is held by the transmission. My wife's 2024 Subaru does this quite noisily which incidentally is on its 2nd transmission. Not saying that's why but just saying.
The above sequence is similar to what one would do if it were a manual transmission.
N
nomech
I noticed this morning when I pulled into my slight incline parking spot and just put the vehicle in park (to see what it does/pay close attention) I did feel a slight roll back when letting my foot off of the brake so the incline was not enough to auto engage the park brake, which I have noticed happened in the past. I'm going to start engaging the parking brake, going forward.
jerry455
I use the parking brake when I am towing my travel trailer. When I am hooking up or unhooking, I get it into position, apply park brake so it doesn't move slightly, and hook or unhook. Keeps truck from moving while setting up.
GMCChevy
To Park:
2.Shift to N
5.Shift to P
6.Engine off
To Go:
2.Start engine
3.Shift to N
5.Shift into gear
You should be able to skip Neutral, makes no difference to the transmission as long as your foot is on the brakes when you engage or disengage the parking brake.
homesick
The Best Me I Can Be
Navy Air Force
The important point is to set the brake before you let the vehicle move- at all.
joe
j91z28d1
To Park:
2.Shift to N
5.Shift to P
6.Engine off
To Go:
2.Start engine
3.Shift to N
5.Shift into gear
this is correct. even with a electric parking brake in my car.. steep driveway, it's very had to get out of park if I don't set the parking brake, pause in neutral, left it roll back against the park brake and then put it into park.
j91z28d1
not on my 11 yukon or 14 volt.. if you shift into park, set the park brake and then release the foot brake, it rolls back enough to put pressure on the tranny park paw. I have to let it roll back against the park brake before shifting into park.
GMCChevy
Usually when that happens, either with GMs or any other vehicle, it's because the parking brake needs to be adjusted or serviced. Especially with the setup the Yukon has. I would guess the volt has the type that's built into the caliper and all that does is manually clamps down on the piston, which is already being applied with your foot on the brake so it shouldn't move at all.
j91z28d1
I thought so the first time I had the gm drum inside rotor style too, that was a 02 camaro, but that car was new and did it, I just figured it had an issue but I never found anything. I've also replaced everything in the rear bakes on this yukon too. they seem to have a good few inches of slop in all of them.
the volt doesn't have it, since like you say it's the caliper piston used for the parking brake but I still do the same thing because it works well. Just set the park brake as you come to a stop, pause in neutral and release the foot brake, then shift to park.
GMCChevy
That's the problem with those drum in rotor ones is that they're hard to adjust properly and need constant attention if used regularely. The only good thing about them is it keeps the calipers simple by not having all those extra parts to them :)
The scary thing is most vehicles I've seen that continue to move a bit after the parking brake has been applied and put in park it's only some friction that's given the sense it's actually done anything. Especially if it's on an incline where you'd want the parking brake holding it in place you can put it in neutral and give it a good shove and make it move :(
Mariam26A
