SgtPreston
- Joined
- Nov 2, 2020
- Posts
- 59
- Reaction score
- 47
Okay, if you read my intro you will find I just purchased a '94 Yukon and the first thing I tried to fix was the poor headlights (a month ago) so I bought some HID/Xenon upgrades from Headlight Experts (btw, I don't recommend their customer support). Had to remove the grill to install the ballasts but no problem there - the LB was pretty good but the HB was like a halo so I swapped the HB for an LED - same effect.
Then I decided to join the TYF and saw the post by "Soulsea" back in Oct. 2012 - did a further search and found that headlight retrofits are as common as water leaks in the passenger compartment (yes, I have one too) on these trucks. Long story short, I've read most of the posts on headlights, and their good and bad points, but what I haven't been able to discern is a final retrofit or product I can pursue for my '94.
I don't want to ask the "What's the best motor oil to use?" type of question but I do need some direction on a suitable headlight replacement that doesn't require major modifications. I'm getting the impression there isn't a PnP application that works in the halogen reflector housing? Any help is appreciated.
