Yukon 6
Im new to this so bear with me I hope I'm not writing on the right page I have a 2004 GNC Yukon all-wheel-drive what is coming over an overpass after I got off of work Alcorn about 25 it just locked up and I skidded to a stop well I thought somebody hit me I should say IHOP to a stop I was sitting there stuck in the overpass so I put it in drive to see if it would go at all I can hear is a loud pop so after that I was able to limp it about a block away to a hotel parking lot had it towed from there to my nephew's find out the gears in the front differential Oregon I was wondering what would cause this every once in awhile the red neutral light would come on the neutral light for towing would come on but it would drive fine just before this happened it went into limp mode a couple times sunnyway got to rebuilt front differential put it in much better and Tighter feeling but now it wants to just stay in limp mode OBD2 codes installing AR 740, 753, 758, 785, 27611 all P codes and when I start it up sometimes. Red neutral light comes on instead the yellow all-wheel-drive light the front transfer case output seal has a leak in it but the fluid is like you keep it. I wonder if this has anything to do with it so those codes are a torque converter clutch enable solenoid circuit, 1 2 shift solenoid circuit, 2-3 shift solenoid circuit and the other one is a 2761 something to do with the torque converter clutch anyway I was just wondering if anybody had any idea where to start troubleshooting at I got power going through that transmission fuse which Powers all those solenoids I'm just wondering since it would be very rare that they would all go out at once but I haven't checked at the tranny 4 power and I'm am I in the right sequence at troubleshooting this or do I need I need somebody's advice on how to troubleshoot it if possible thank you in advance
