New build issues
Stage2Tahoe
I just rebuilt my 03 Tahoe. I upgraded from the 4.8 to a 5.3 with tsp stage 2 cam and long tubes. I also put in a new stage 2 trans. I have the startup/idle tune set. For some reason though the transmission won’t shift through the gears. I’m not sure if there is a sensor not connected or if the neutral safety switch needs to be adjusted. It shifts into reverse and drive fine. It just doesn’t upshift. I did notice when I ran a scan in hptuners that it is showing it’s in 1st gear even when it’s physically in park. Any help is appreciated.
strutaeng
Dallas, Texas
The NSS on the transmission has some slots to fine tune the position of the cable. I doubt that's the problem, because if it's off a bit, it will won't crank because it thinks it is in Reverse. And if the cable has too much adjustment, you won't be able to put it into Park.
I haven't checked HP Tuners to see what the program says when I put the lever on Park [thinking emoji].
Do you see the up gear changes on HP Tuners? Are you saying it won't upshift 2, 3, 4 at all? There are some parameters you can add on the channels for the transmission. You can add some of those and do a log to see if you can try to figure out what is happening.
Did you get a tune for the 5.3 with the aftermarket cam?
S
Stage2Tahoe
It’s not up shifting at all. It’s like it’s locked out in first gear for a dyno pull, but I never made any changes to the transmission tune. I’m not getting any feed back in the scanner for speed or selected gear either. I am the tuner and I just have the startup tune loaded. I can’t finish the tuning until I can get it the upshift to fill the cells.
S
Stage2Tahoe
I haven’t spoke to the builder yet until I have checked everything. That is why I asked for some assistance to make sure I didn’t miss a sensor or a ground strap, etc. I have a 99 Silverado with the same transmission and they do good work. So I’m pretty sure it’s not the transmission. I did have to replace the neutral safety switch, but it is showing on the gauge cluster as I pull through the gears. I am getting a code though to service the transfer case.
NickTransmissions
Sin City
The transmission bench
The MLPS (aka Neutral Safety Switch) won't have any impact on the transmission's performance/behaviors. You just won't be able to start the vehicle if it goes bad, unless you electrically bypass it. The pressure switch manifold assembly, inside the trans, is responsible for communicating range position to the ECM so the ECM knows what state the trans is in and can command it accordingly.
I'd check that as well as your vehicle speed sensor signal to the ECM. No VSS signal, no upshift from first gear.
S
Stage2Tahoe
Hptuners isn’t showing a change in the scanner when I physically shift through the gears. It should be changing, but there is a disconnect somewhere. I have also driven the Tahoe down the road and HPT isn’t registering a speed either. I can setup channels to scan the transmission but it won’t matter if the scanner isn’t reading the manual shifts from the gear selector.
strutaeng
Dallas, Texas
Does your speedometer work?
S
Stage2Tahoe
No the speedometer isn’t registering. That is why I am having abs and brake system messages on my gauge cluster also.
alexblagoev
