New air ride compressor went bad after a few months
Bill 1960
Testing the Limits
If you had leaks (compressor ran a lot) the compressor can burn itself up from overheating.
Shtiv
Shtiv
Seattle
New one still isn’t working, could the old one have blown a a fuse?
adventurenali92
Big Bear Lake, ca
It could have but it’s unlikely. Didn’t you say it ran once or twice and then It hasn’t ran since? That would indicate that the exhaust solenoid is bad.
It’s not coming on because the shocks are already full and the exhaust solenoid isn’t opening the vent to release any air so the compressor won’t come on while the shocks are still full. Unhook the air lines at each shock and let the air out of them. Then rehook the air lines up and turn your key on. If the pump kicks in and fills them up, then that’s the sign that the exhaust solenoid on the pump is bad and you need a replacement pump and solenoid.
Shtiv
Shtiv
Seattle
Not yet, going to do tonight. Is it a bad idea to install my new front shocks prior to getting this compressor issue squared away?
Shtiv
Shtiv
Seattle
New one hasnt turned
new compressor hasn’t turned on at all.
adventurenali92
Big Bear Lake, ca
Front shocks will be fine. They’re not air shocks. The front auto ride shocks are just a standard shock thats electronically dampened via the trucks computer. So putting those in won’t affect anything in the rear.
Make sure the power harness going into the compressor is fully seated into its clips and connected properly.
Check the ground at the compressor, it gets rusty or corroded and that’s just as important at the positive side. There should be a ground wire with an eyelet right at the compressor that goes to the frame.
44Dan
