My Non Recalled 2024 Yukon L87 Engine Is Failing - Full Of Metal @ 17k Miles
Vladimir2306
With all due respect, you're talking complete nonsense. Many videos show issues with the crankshaft on L87 engines. If you choose to ignore the evidence, that's on you. And to say Lake Speed, Jr. is talking nonsense is absurd. The man has forgotten more about engines and oil than all of us know.
Look, I've been writing on this forum for the second or third year now about the fact that the oil change is 0-40, and even 5-30 not needed. I have always written that oil is not the cause of engine failure, even posting an oil analysis of 0-20 after 7000 miles. And it was still normal. Unlike the author of this topic, who was looking for reasons in the oil, then in a bunch of other things, then in the amount of gasoline in the oil. And did it help him? The answer is no. his engine also broke down.
Now, as for this blogger and the video. Yes, he confirms my words that oil 0-40 will not help, and I drove off with my first engine running on oil 0-20, and after installing the second engine, I also ran on oil 0-20.
But, as for the roughness and undulation...This is nonsense. In order to do a qualitative analysis, you need to get, disassemble and study the new L87 engine, rather than using engines that have not passed the Pico test. This is not objective, it is clear that an engine that has not passed the Pico test will already have crankshaft wear. This is logical, and so will the roughness and undulation. So, I repeat once again, there is no problem with the crankshaft of this engine. Why am I so sure? yes, because they don't touch the crankshaft about installing a new engine, and they didn't touch the crankshaft for me, they polished it a little, it's not significant, that's all.
And if you know at least a little about metalworking, then to remove the undulation of metal, you must remove a sufficiently large layer of metal, because of this, the gap between the liner and the crankshaft will be huge.
So, our services in Russia have already supplied more than one L87 engine after the breakdown, and can you imagine? none of them has ever broken down again. None at all. And we are actively discussing these cars. And there are cars with runs of over 120 thousand miles after repair and/or installation of a new engine, just like my engine at the time of sale, after installing a new one, it passed 50 thousand miles without any problems. On 0-20 oil, with replacement every 7,500 miles, without using the L9, or the Range unit, I just drove the Yukon and that's it.
So what were the jobs? For me, as for other L87 owners, the service technicians disassemble the new engine, sharpen the cylinders so that the piston fits normally into the cylinder. After measuring the gaps, in some places there was no gap at all between the piston and the cylinder. Here is a photo of a new piston from a new 0-mile engine. Next, change the crankshaft inserts to red ones. I wrote about that too, and that's it. The engine is being assembled. The crankshaft is left the same, everything remains as it was, except for the gap between the cylinder and the piston and the replacement of the liners, and of course the maximum cleaning of the engine inside. All...this is the only thing that is done, and after that the engines run without breakdowns, unlike in the USA, where owners are given 2-3-4 engines in a row.
The reason for the breakdown of the L87, I announced 1.5 years ago, is the poor quality of the cylinder block processing, that's all. Even the red liners are more of a reinsurance, because after bringing the engine to GM standards, there will be no production of liners.
And yes, as I said, he's talking nonsense about 10th gear on automatic transmission, these cars don't drive in 10th gear practically, well, at 50 miles an hour, if only on a flat road. And then, it's worth changing the slope of the road a little, or pressing the accelerator pedal, immediately the engine switches to lower gears. I posted a picture where I was driving at 105 mph on a flat highway, and the engine was running at 3,000 RPM without shifting into 10th gear. I do not exclude that GM, realizing the danger of 10th gear, specifically removed the gear indication in the T1 generation so that the owners would not see that the car was not using it practically. And yes, most likely for the same reason, fuel consumption on the highway for the T1 generation is higher than for the K2 for the same engine.
LEsoftballdad
Suffolk County, NY
Look, I'm not even saying you're wrong about the Russian fixes, but what you're describing isn't a simple fix. You make it sound as if it is a quick fix, yet you suggest pulling all the cylinders apart, and removing the crankshaft. That's a major undertaking. For all intents and purposes, that's a rebuild.
What Lake Speed was saying, and he's not just a blogger, is that it's *not* an oil issue, so GM's fix was a joke. You can criticize him all you want, but I'm taking his expertise over yours. He literally runs the foremost oil analysis company in the country, and he helped build engines for NASCAR teams for years.
Vladimir2306
Of course, this is a serious action, this is the overhaul of the new engine. But these actions show where the problem is, and what actions help to solve it. Look at one more thing, the years are coming and the warranty on the L87 will end, and the owners, even in the United States, will have only two ways, either to fix it as it is already being repaired in Russia, or to put the 5th generation GM under pressure. And again, the most important thing is that GM does not spoil the 6th generation and the famous 6.6 engine with its modifications.
Vladimir2306
I saw the video. Now I get what you meant about all being revealed.
I found another video in my collection. This is just my new L87 engine, which was installed for me after the old one jammed. It's in Russian, but it's easy to understand what the mechanic is saying through a translator. There, the piston simply does not move freely in the cylinder. This is my new engine, before it was given to the cylinder boring, this is the engine that GM sells, they took it out of the box and disassembled it, and they put the engines in there, and the 25-26 year L87 are exactly the same.
Nagloc68
I may have posted here before. We have one of these engines in a 2023 Cadillac Escalade. Passed PICO. Received a warranty extension to 150k miles on engine. Service tech at our dealer in chicago area said they replaced an engine for a customer, and the replacement died in a few months. Same problem. So, that suggests GM hasn’t fixed the problem, yet. I have my fingers crossed. Not much more I can do.
KMeloney
Uh, yes, it certainly does suggest that.
ZKWBQD
ZERO service at any dealership, I do ALL my own work. Only dealer visit was recently for a Pico test for a vehicle/engine that is/was not part of the 600,000 recall.
The problem is the current batch of disaster Reman L87 are probably less reliable than the builds right off the engine assembly line, sad but true. GM could have done the right thing and had the Remans come out more reliable than the assembly line engines.
Not worried about GM, I really am not. If the vehicle gets an engine, it will be built and configured by my requirements and it will likely last for 200,000+ miles, if it did not have DFM and the fragile lifters, it would go for 300,000+ miles. It is possible. GM screwed in many ways on this engine, the highway loading is killing these engines the way the crank was shipped, the bearings they chose and the stupid variable displacement oil pump that constantly modulates back and forth on volume one a specific pressure at the pump, not the front main oil galley has been reached.
Love your suggestion to scrap a less than 2 year old vehicle with 17k miles!!
The purpose in all of this is to find out the "Why?". What went wrong? I am the person that is a major troubleshooter and will get to the "Why?" I have done for years and it just is in my nature. There is a group currently looking closely at what has gone wrong with these L87 and I think in the near future, there will be some answers. Seems nobody up to this point has many answers, specifically the manufacturer seems clueless because even 2026 L87's are failing almost every day. The machining debris IMHO is often just a smoke screen cover story to differentiate a "Process" problem from a "Poor Part Choice" or a "Design Defect". This matters sometimes at the end of the day, much cheaper and easier to blame a component supplier than to own it.
The issue is there are probably over 1,000,000 L87 mid size trucks and large SUV's that have the L87 and people are going to want to repair these without some GM Reman that may not last as long as the original engine. If we figure out exactly what is required to be changed, upgraded, replace in these L87's, then they can be come safe, reliable vehicles for the owners.
If you did all of your own work, be prepared for resistance if you need warranty service. At a bare minimum, keep receipts for all your purchased items and preferably photographs of the job being done. "If the vehicle gets an engine, it will be built and configured by my requirements". That's not going to happen at a GM dealership.
Marky Dissod
You guys need to read between the lines a little more ... This is not some random guy turning a wrench in his garage.
Reading between the lines more, is not something most people are great at.
Also, despite the existence of the Magnusson Moss Act, he ABSOLUTELY NEEDS BE PREPARED for unjust resistance to any warranty service claims.
LEsoftballdad
Suffolk County, NY
I thought it was interesting that Ford announced that their 2027 5.0 Coyote engine will have neither auto start/stop, nor cylinder deactivation. Maybe they actually listened to the consumers.
Marky Dissod
I thought it was interesting that Ford announced that their 2027 5.0L Coyote V8 will have neither auto start/stop, nor cylinder deactivation.
Every so often customers are too dumb to be listened to, but this is not one of those times.
A.S.S. & Cylinder Confusion are just not worth it, not to carmakers who need to include extra computational ability to pys off their customers,
not to customers who get pysd at paying more for rough starts every traffic light & odd throttle responses to save a whopping *1-2MpG*.
*Short rant
MpG is actually a dumb way to measure fuel consumption, because it's not linear; the MpG scale LITERALLY represents diminishing returns.
Gaining 2MpG is more of a positive impact on fuel expenses from 15MpG-17MpG, than from 23MpG-25MpG.
Meanwhile vehicles are getting heavier and increasing drag area ...*
ANYWAY
Until vehicles start getting lighter and decreasing drag area, fuel economy 'improvements' are not going to save consumers any money.
RET423
They always listened to the consumers, but the govt decides what they can sell; not the consumer
The moment the EPA backed off, the car companies started getting rid of garbage nobody wants
Mini trucks will likely be coming back soon as well, good things happen when the Market decides what it wants instead of the Gestapo
frydaddy96
Here's my observations from my towing trip. Normal oil temp idle looks like 25-30 psi, foot off brake and touch the throttle psi goes to 50-55 pretty quick. Rolling down the road, psi was consistent ~55, RPM from 1500 downhill to 2700 going up hills/grades. On the longer up grades it would kick down further to 3200-3500 rpm and the oil press would get to ~58, the indicator never touched or got to the 60 mark.
The instant fuel economy was hanging around 7-9 on the flatter to slight up grades sections of road. It would drop to 4 when kicking down to the higher rpms and steeper grades.
Just over 10K (½ of that is towing)miles after this trip, so oil change time. Putting a magnetic plug in and will see what the filter innards look like.
J
jfoj
@frydaddy96
Thanks for your information. Question about your oil pressure values. Their variations on the vehicle based upon type and year, are you just using the oil pressure bar graph or do you have a newer 25 or 26 that you can bring up and display the actual digital oil pressure gauge and see an actual numerical reading?
At leased via the OBD port, the oil pressure seems to hit in the neighbor of 80 to 85 PSI from what I've been seeing on my vehicle. In retrospect, I kind of wish I would have put a "T" in at the oil pressure sensor to verify that the OE sensor is accurate and to see with a more sensitive transducer exactly what the oil pressure would typically do under operating conditions.
While everyone seems to think that 50 to 55 PSI of oil pressure is adequate, Oil pressure is just the resistance to flow, it really doesn't tell you the volume of oil getting to the critical areas like the bearings. The problem or the challenge on these engines is the piston oil squirters have check valves trip between 43 and 45 PSI, so you start dumping a fair amount of oil volume to cool the pistons upstream of the bearings. The piston oil squirters are in the oil galleys that feed the main and rod bearings so the piston oil squirters clearly can take pressure and volume away from the bearings.
Just think about what happens when you're taking a shower in the house and somebody turns the water on, the dishwasher or washing machine kicks on or a toilet is flushed. You tend to have a drop of pressure/volume in the shower until the other appliance shuts off. I suspect this is part of the issue with the L87 and the bearing wear, which ultimately leads to spun bearings
If my data is correct that I've seen 80 to 85 PSI oil pressure when the second stage is kicked in, one has to wonder why would that amount of pressure really be required for any engine unless there's enough restriction and contention for oil volume and flow for the bottom end of the engine.
The other thing that everybody needs to understand is it appears that around 50-55 PSI Is where the first stage oil pump tends to top out on pressure. And once the oil pump tops out on pressure it starts varying displacement or volume. The oil pump variable displacement mode is determined based upon the back pressure within the pump. Not a pressure reading in an oil galley toward the end of the oiling path within the engine. Not a good situation because the oil pump is doing one thing at the source and there's no consideration for what the pressure and volume is at the end of the oiling path within the engine.
Vladimir2306
@frydaddy96
no, nothing varies, the oil value is the same on all L87, any years from 2021 to the present. If it changes, it changes for everyone when the car software is updated.
frydaddy96
I only have the ability to use and see the bar graph. I have a port reader that I use on my Tahoe, I will hook it up to the Silverado to see what it will read.
I'm wondering if the computer management software is controlling differently between the SUV's and the pickups? Even when the RPM's would go to 3500 the bar graph only moved a bit closer to the mid mark but there was still black space which is why I was guessing 58 psi. After topping the grade and the RPMs dropped the bar graph shifted back the little bit and maybe sometimes would shift back and forth like say 50-55 a little bit before stabilizing.
I have noticed several times after a gas stop and getting back on the interstate, that once up to speed, the RPMs stayed around 2250 - 2500 (guesstimate) for a while on flat road and into some small rises then on a down grade it will shift to lower RPMs when on more level road. After that the RPMS seem to be where they should be for up or down grades.
On previous towing trips, I've had over 4K rpm but don't recall seeing the oil pressure bar going higher than the 60 mark.
My OBD reader doesn't pick up oil press or temp, it reads a lot of other stuff but not those.
Vladimir2306
That's right, here's a photo of a Yukon driving with a trailer at 87 miles per hour, on a flat highway. Engine speed is 3700, oil pressure is 58PSI. It rises higher only when accelerating in the pedal-to-the-floor mode.
alexblagoev
