@Vladimir2306
You have so much bad data and are spreading misinformation.
The 6.2l with the 10 speed does uses 10th gear a lot. You are close in indicating the vehicle will go into 10th at 50 MPH, it actually can and will go into 10th gear at least as low as 45 MPH depending on the load conditions. I have plenty of data showing 10th gear on rural secondary roads with 40-45 MPH speed limits.
The vehicle will stay in 10th gear above 90+ MPH as long as you are cruising and not passing. Even if the transmission downshifts, 10th to 9th gear event with TCC slippage is only about a 100 RPM increase. Except for you driving for hours at 100-120 MPH, this does not happen in the US, far too much enforcement and traffic. The L87 rarely sees above 1700 RPM unless you are merging onto the highway or passing on the the highway and in this case the engine will likely hit 3500-3700 for short periods. The 2nd stage oil pump control is RPM based from all the data I have collect and does not trigger until 3000-3200 RPM as which point the oil pressure increases to 80-85 PSI, all other times it is around 50 PSI on the highway and as low as 35 PSI at idle.
These engines are killing themselves with the Low RPM lugging as well as questionable oil pump control, additionally the crank machining and finish may be playing into the problem as well. GM DID NOT change the crankshaft part number, but they were supposed to have cleaned up machining tolerances and overall crank finish in late 2024 however, it appears they may have miss the mark on that issue.
I firmly believe that these lightweight 0W20 and thinner oils are just not suited for the high power density of modern engines. It leads to requiring far more precise machining and clearances that once were plenty good enough and also contribute to increased oil consumption.
5W30 has worked fine for over 40 years in the majority of the V8's, however the new higher power density and higher low RPM Torque 5W30 may or may not be adequate. I believe it can be, however, the 10 speed transmissions keep the engines close to peak Torque for better fuel economy and this is putting a lot of loading and strain on the bearings as well as the engine blocks.
