Squirrelsmith
- Joined
- Jan 21, 2018
- Posts
- 914
- Reaction score
- 788
A guy at work convinced me it was the best thing since sliced bread... here is what i have going on
keep in mind that I know very little about cars and am totally freestyling this so take it with a grain of salt i suppose. Let me know if you see anything wildly wrong with my plan haha!
went to junkyard and pulled the hydroboost unit along with the master cylinder off a astro van, I think i spent $40
got hydroboost power steering lines for a diesel 98 tahoe from rock auto $50
power steering cooler and fluid from napa $40
refurbished power steering pump for a 98 diesel tahoe from some random place online $50
still need might need some more 3/8" hose and hose clamps for running to and from the cooler.
I might get this done for under $200
Here is the problem i ran into.
the "push rod" that come through the firewall from the astro has a smaller hole and is almost exactly 1" shorter than the one off the stock vacuum booster.
So I cut off the astro one and drilled / tapped it for a m5 screw. I then cut off the stock vacuum booster one and threaded it with a m5, screwed the two together with loctite. This added the inch and got me the right hole for the connection to the pedal.
you can see where I made the splice there is a color change. I don't anticipate any more problems but I will update with the good or bad time I'm having.
