Mushy brakes
YukonXLMan
Assuming brake rotors and pads are good, bleading your brakes and changing out your old brake fluid for new has helped me. if rotors and/or pads are bad, change them out. What are your symptoms?
BG1988
replace the brake lines
the elcheapo rubber hoses are worn out
but it's the hallmark of GM Excellence of the 90-00s
AFM = the hallmark of GM Excellence of the 00-10-20s
Yup- Assuming all the components are already up to par: Full fluid flush and braided steel flex lines would make quite a difference. As Kevan sad, a hydraboost conversion would be the ultimate fix.
TheAutumnWind
Ive got stainless lines and fresh fluid
My OBS truck stops great, its light so that helps, but all the travel before pad engagement is super annoying.
I intend to swap an nbs mc in my obs.
TheAutumnWind
What can be done to make the braking better ?
Those giant wheels didn't help your braking situation I'll bet. You can swap to nnbs front calipers and rotors, which requires modification. Or you can upgrade to the obs srw 2500 brakes which have bigger calipers and rotors and mc, which is a bit more straightforward.
I'd just start with lines and fluid and more aggressive pads and see what that gets you.
Some people choose to swap in the nbs master cylinder for a better brake feel
iCajun
Check the adjustment on the rear brakes occasionally as the star wheels get stuck.
mont
