John03Z71
- Joined
- Mar 27, 2014
- Posts
- 43
- Reaction score
- 14
I have an 03 Tahoe Z71 5.3 that has been running a bit rough for quite some time. When I say a bit, I mean a few misses when idling, slight hesitation when accelerating before normal performance, shuddering/shaking randomly on and off when stopped in traffic or at red lights. Enough to be annoying but never bad enough to motivate me to investigate much further (busy work schedule/travel and two young kids = not much free time to tinker around). About 2 weeks ago I had a rare free weekend so I decided to try and solve the problem by changing the plugs and wires, which was overdue (probably been 80k at least).
Immediately afterwards I test drove and noticed horrible performance... it was the same misfiring issue I had before but it was 3x worse. Idling in traffic literally makes my whole body slightly jerk back and forth it shudders so hard. If I stomp on the gas it sounds horrible and is so bogged down.
I checked all connections and all are snug and going to the correct plugs / coils. I even swapped a suspected bad coil (passenger side closest to the firewall) this weekend but no change. Tonight I decided to investigate more and come to find out there is a visible spark that is coming off that plug (rear most passenger side) outside the wire boot. I triple checked for a snug fit and even swapped the wire out with another one but it still does the same thing. Audible snapping sound with visible spark outside the plug boot, and every time it does that the engine dies down significantly. What could this be? Ruled out the coil and wire, and the plug was new 2 weeks ago. I suppose it could be a bad plug but I didn’t have time to swap it out and see if the same thing happened on a different cylinder.
My question to you guys is what does this sound like, a bad plug from the factory or does the visible misfiring spark outside the rubber boot indicate a different issue?
