grouch
- Joined
- Jan 23, 2019
- Posts
- 1,254
- Reaction score
- 2,887
Short days and long work times is making this difficult to track down. I had my '93 C2500 GMC pickup singing a song but it's started misfiring when warm. When you first start it, it fires right up and runs smooth with plenty of power. As it warms up, it begins to run rough and stutters under load. The stutter is getting worse.
When I got it, I replaced the cap, rotor, plugs, plug wires along with the coolant sensor. This isn't like the bad sensor issue. It was off time by a couple of teeth so it has a new timing set. It's definitely a heat soak problem. I'm wondering if the coil is giving me trouble. I replaced the old one due to rodent damage and I may have gotten a defective one. I get home after dark so it's getting it off to bench test it that's the problem. Can anybody think of anything else that could cause this? 350 engine and automatic.
