While i am only considered doing the passive for the rear, i will probably need to replace the front struts soon. The Dorman compressor is actually more than the arnott if my mechanic orders it.
i am always loaded with tools for construction and often lumbering materials on the roof.
I did get 35% heavier springs from Dayton,& new insulators…for this remediation.
This is the second mechanic who “suggested” going with non z95 shocks.
From what i gather, the oem shocks have an airbag at the top which is pressurized according to the weight of each load. This weight is calculated by the ride height sensors and only activates the compressor at start up, not continuously adjusting throught the drive.
The Z95 suspension has both an electrical and pneumatic air component.
The Z95 OEM shocks have an electrical connection on all 4 shocks, which constantly adjusts the stiffness of each shock independently, based on road conditions and input from several sensors in the truck's electrical system (wheel speed sensors, wheel hub accelerometers, ride height position sensors, yaw sensor, steering angle and steering wheel movement/change speed inputs, and drive mode selections if applicable). The reaction time for the shock to adjust stiffness, based upon the signal it receives from the control module to its electrical connection is 4 milliseconds, which is why they are so effective in producing ride comfort.
For the GMT900 trucks, the Z95 rear shocks have air bladders on the shocks that keep the truck level, regardless of the load carried, through the air compressor. The ride height sensors provide input regarding the 'levelness' of the truck, and air is either added or removed from the rear shocks air bladders by the compressor and bleed valves, in order to keep the truck level. This adjustment takes place when significant weight is either added or removed from the truck. Upon starting the truck, the Z95 system initially bleeds some air from the air bladders, and then adds air to bring the truck to level. This is also a test function and activates the compressor for 4-6 seconds to add air to level the truck, and confirm that the system is functioning as it should. This system is capable of keeping the truck level from unloaded to a full 1/2 ton load.
If your combined tools and typical lumber/cargo load is 1/2 ton or less, the Z95 suspension is fully capable of handling your load. The fact that you put 35% heavier load springs on the rear will increase the stiffness of the ride a bit with the Z95 suspension, but it will still perform its function.
