Low Speed Noise....
RockoC
N.J.
I have a very annoying noise that only rears its ugly head when turning and going over bumps at very low speeds. It sounds like something is straining. It sounds like it's coming from the front passenger side wheel well so, over the last few months, and after three shops (including the Chevy dealer) misdiagnosed (replaced parts that did not fix the issue) or outright failed to diagnose the issue (replaced nothing and gave me back my keys), I started blindly replacing suspension components in an effort to eliminate the noise and save a lot of $$$ on labor.
I replaced/had replaced: all four control arms/ball joints, the struts, sway bar end links, sway bar bushings/brackets, and outer tie rod ends. To my limited knowledge, all that is left of the major suspension components are the inner tie rods and the hub assemblies. The mechanic who replaced my outer tie rods said the inners were tight and another mechanic checked the hubs/bearings for "run out" and said they were good. Based on where the noise sounded like it was originating, I would have bet it was the upper ball joint. Wrong.
I was literally shopping for a nice used 2023/2024 Tahoe/Yukon when I came across a video on YouTube of a guy replacing his lower steering column bearing with a Wolff Engineering part. What struck me about the video were the symptoms he described. They sound exactly like what I am experiencing. I have zero play in my steering, btw, just the maddening noise when pulling into/out of a parking spot, my driveway, etc.
My questions are:
1. Has anyone experienced this and replaced the bearing on their 2015-2020 Tahoe/Yukon/ Escalade?
2. How difficult was it? I found plenty of videos for the older generations, but not mine.
2a. Speaking of which, I watched a video of a guy replacing the bearing on his 2011 Silverado and he removed the entire steering column. Yeah...I'm not doing that.
3. Did you also replace the intermediate steering shaft or is that repair related to play in the steering?
As always, your help, advice, experience, etc. is greatly appreciated.
Thank you!
RockoC
RockoC
RockoC
N.J.
I spoke with a tech at Wolff Engineering. He confirmed that removal of the steering column is required to install their upgraded bearing assembly (GM309SS) on my generation Tahoe. As stated above...I'm not doing that.
I did replace the upper intermediate steering shaft yesterday with the factory GM part (85104192). The original shaft was rusted, and the grease had squeezed out (see pic), but unfortunately, it did not solve my 'noise' problem.
Thankfully, my adjustable pedals made the install much easier. I did not have to remove the gas pedal (as I've seen several guys do on YT). It was a tight squeeze under the dash, but the entire project took me about an hour. I torqued the bolt in the engine compartment, but I couldn't fit the wrench under the steering column, so I tightened it as much as I could and used blue Loctite.
The most time-consuming part of the replacement was getting the hidden shaft boot nut back on the stud. The brake master cylinder makes it impossible to see what you're doing, but I got lucky and got it on and tightened it on the 2nd try.
I'm taking it to a friend's shop on Wednesday to see if they can diagnose the (worsening) sound.
alexblagoev
