Loud Bang Pulling into a Parking Spot - Solved
RockoC
N.J.
I'm at wits end (& broke trying to fix this).
Picture this: I pull into a parking lot, stop, turn the wheel all the way to the left, then back into a parking spot. While doing so, I hear a loud bang that reverberates through the steering wheel. The following parts have been replaced within the last 9 months:
1. Lower control arm w/ ball joint
2. Front struts
3. Both outer tie rods
4. All brake pads, rotors, and brake lines
5. Sway bar bushings/brackets & front and rear end links
6. Rear main seal and oil pan gasket
7. Fuel pump
8. Both CV axle shafts (done yesterday)
I realize all of the parts listed are not suspension-related; I'm just listing them to correlate with the 'broke' comment :)
I really thought replacing the axle shafts was going to finally fix the problem, but it didn't. Unless they need time to break in, but my mechanic didn't say so.
I did the struts, brakes, and sway bar stuff myself; I paid for everything else.
Anyway, I'm open to ideas. I was hearing another noise when turning that, thankfully, is gone, but this loud bang startles me when it happens. It only happens when the wheel is turned to the stop and I move forward or reverse. Again, usually when pulling into a parking spot from a near 90-degree angle. This has been happening since around February. Zero issues before then.
Please let me know what you think or if you have experienced this yourself.
Thanks!!!
RockoC
CrashTestDummy
Pearland, Texas
Could be as simple as the tire slipping when backing in while the wheel is turned. The wheels in these vehicles don't track the same line, and the difference gets greater the more the wheel is turned. You can sometimes hear the slipping that sounds like popping as the tire moves, and sometimes hear it AND feel it as a jolt. It depends a LOT on the surface you're on, especially sealed asphalt.
But verify it's not something really broken, like the motor/rack/diff mounts. Additionally, just because something is freshly-replaced, doesn't mean it's good. Verify the front axles are still seated in the diff.
RockoC
RockoC
N.J.
Thank you for all the replies; you've given me plenty to think about.
To answer Dave09's question: no, the upper CAs and ball joints are still original but definitely need to be replaced. Well, the ball joints and bushings need to be replaced, but at that point I would just replace the control arms and caster/camber hardware. The rubber boots on the ball joints are torn. Only God knows for how long and how bad they are inside. My wallet needs a break. I might do them myself and let the shop do the alignment. I've spent over $15k since last Fall. I had my eye on a 2024 Tahoe RST...I should have pulled the trigger. Hindsight and all....
Thanks again, everyone!
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Depends on cost, mileage, maintenance and tires on the 2024.
Could have bought a creampuff GMT800 and been way ahead.
DaveO9
Vancouver, WA
I’d go ahead and do both upper CAs, even if they’re not the source of your noise. Uppers are pretty easy to do yourself, and a ball joint failure on the road is catastrophic. Unfortunately, if lowers have torn boots as well, you also need to do those.
Most on here will recommend GM OEM or (maybe) AC Delco Gold. But I used all Delphi for those parts. Delphi in my book is a good balance of cost vs quality, and they were identical designs. Delphi is an OEM supplier to GM, too.
Los Angeles, CA
Crossmember bolts tight?
this issue was my culprit when I rebuilt my friends 2006 avalanche ls engine and suspension overhaul. when he turned the steering wheel we would get a clink/clunk sound. over looked these bolts re-torqued everything and then a week later did this, problem solved
StinkyLinky8
Bucks County, Pennsylvania
2. Front struts
7. Fuel pump
Thanks!!!
RockoC
I went down this rabbit hole as well. Thought my bad motor mounts must have been the cause but the sound came back a day after replacing them so I asked my mechanic to drive it for the day. For some reason it only seems to happen once the engine bay is up to temperature too but that might just be in my head.
He gets back to me and tells me my steering rack bushing are worn out and that there are 4 bad bushings but GM says only 2 of which are serviceable. It’s been doing it for about 70k miles and is slowly getting worse.
I’m still looking for replacement bushings or options at this point. I keep hitting dead ends when it comes to researching the steering rack bushings so it’s on the back burner for now.
Might be worth looking into.
RockoC
RockoC
N.J.
SOLVED! - Forget what I posted here about the strut mount. It was not the issue. It didn't solve anything...although those nuts are NEVER coming loose now ;)
I still can't believe this, but it was the driver's side sway bar bushing. Yeah, you know, the new one I just installed. To make a long story short, I didn't know that if you removed both sway bar bushing brackets at the same time, the bar would drop an inch or three. Making it super easy to install the new bushings.
I did them one at a time and used a pry bar to create a little space and wedge the bushing in place. The bushing was twisted and under tension the whole time. I knew this but couldn't get it 'even' and didn't think much of it anyway.
I bought new Suspension Dudes rear sway bar end links, and they threw a set of front links in for free. The rears were simple to install. I bought a pair of front bushings from the same company (figuring I would install the front links and bushings at the same time) and, before I installed them, I just happened to watch a YouTube video of a guy installing new front bushings. When he removed both brackets and I saw the bar drop, so did my jaw. I couldn't believe it.
I installed the new front sway bar end links - without jacking the truck or removing the tires, btw - and bushings last Friday. The sound is completely gone. I've really tested it and tried to make it happen...and nothing. I can't believe a $10 bushing - and my inept installation - gave me that much grief.
So, folks, learn from my ineptitude. This is why we're all here, anyway, right? To learn from each other.
When you get ready to replace your front sway bar bushings, remove both brackets/bushings at the same time, lube the bushing, snap it on the sway bar and slide it in place. Install both brackets finger tight, then torque them to 37 ft/lbs. It was SO easy. It took about 20 minutes. I'm no longer looking for a new truck...that's how happy I am (and how crazy the sound was driving me).
Ciao'
OR VietVet
Willamette Valley
SOLVED! - kinda'.....I left my truck with my mechanic while I was away for two weeks. They were finally able to reproduce the noise I'd been hearing but after going over every part of the front suspension, they were stumped. I picked it up, VERY frustrated, and decided to pop the hood and re-torque the new struts - something that had slipped my mind after installing them. I didn't think it had anything to do with the noise, just something I forgot to do that needed to be done.
Lo and behold, the nuts had come loose and the studs had moved around enough to widen the holes in the frame. The banging I'm hearing is the top of the strut shifting in the frame under load.
Now that I figured that out, what the "F" do I do about it? Two of the three holes are enlarged about 1/8" in an oval shape. I removed the scrawny KYB nuts and reused the OEM ones, which are much bigger and cover more area, but it didn't fix the issue.
Anyone run into this before? Does someone make sturdy lock washers that will do the job? Do I exceed the torque specs? Is there some kind of kit I can buy (and probably have to have welded to the frame)?
As always, your responses are GREATLY appreciated. Thanks!
Doesn't sound like you have tried over tightening the nuts yet. Do that first and see is the noise changes and/or disappears. Next, you can use no washers but use the nuts that have a washer like flange on one side that has serrated cuts/grooves in them that will grab in to the surface and keep the stud from shifting in the hole.
The next drastic choice is to remove struts and clean to bare metal at the top around the stud and also at the holes where the studs stick through. Reinstall the struts and tack weld the hole to the strut plate and then install the serrated edge nuts.
You can also "add metal" to the holes and redrill.
RockoC
RockoC
N.J.
Thank you for your prompt and detailed reply. I will definitely try your solutions in the order you suggested. I'll report back afterward.
Again, I appreciate you taking the time. -RockoC
Fless
Moderator
People's Republic of Colorado
Those are called serrated flange nuts.
If there's enough thread on the struts, you could also weld a (grade 8?) washer to the top side of the mount, either matching the size of the center hole of the washer or buying one with a smaller hole and redrilling to size.
RockoC
RockoC
N.J.
I torqued the OEM nuts to 50 ft/lbs, but it is still happening. I'm not sure what a safe torque range is, given the OEM spec is 37 ft/lbs.
Going to try the serrated flange nuts next and go from there. I might go with one of the welding options if that doesn't work; I won't be replacing the new struts for a long time.
RockoC
RockoC
N.J.
I couldn't find serrated flange nuts with a wide enough base, so I ordered "Extreme-Vibration-Resistant Wedge Lock Washers, Steel" from McMaster-Carr. Once installed and the struts are 'locked,' I'll report back with my results.
Any thoughts on a safe torque range, based on the GM spec of 37 ft/lbs?
Lastly, if it were the hub assembly/bearings, it would make noise turning in both directions, wouldn't it?
RockoC
RockoC
N.J.
I posted this in the middle of the thread and decided to move it here so more folks see it:
I still can't believe it, but it was the driver's-side sway bar bushing. Yeah, you know, the new one I just installed. Long story short, I didn't know that if you removed both sway bar bushing brackets at the same time, the bar would drop an inch or three. Making it super easy to install the new bushings.
I did them one at a time, using a pry bar to create a little space and wedge the bushing in place. The bushing was twisted and under tension the whole time. I knew this but couldn't get it 'even' and didn't think much of it anyway.
I bought new Suspension Dudes rear sway bar end links, and they threw a set of front links in for free. The rears were simple to install. I bought a pair of front bushings from the same company (figuring I would install the front links and bushings at the same time), and before I installed them, I happened to watch a YouTube video of a guy installing new front bushings. When he removed both brackets and I saw the bar drop, my jaw dropped too. I couldn't believe it.
I installed the new front sway bar end links, new brackets, and the bushings last Friday, without jacking the truck or removing the tires, btw. The sound is completely gone. I've really tested it and tried to make it happen...and nothing. I can't believe a $10 bushing, and my inept installation, gave me that much grief.
When you get ready to replace your front sway bar bushings, remove both brackets/bushings at the same time, lube the bushing, snap it on the sway bar, and slide it into place. Install both brackets finger-tight, then torque them to 37 ft/lbs. It was SO easy. It took about 20 minutes. I'm no longer looking for a new truck...that's how happy I am (and how crazy the sound was driving me).
Ciao and thanks again for all of the helpful suggestions,
Rock
alexblagoev
