looking to get into a 2018-2020 Denali Ultimate - BOUGHT
Bob Lob Law
Hello,
Name is Jeff. I Have driven trucks for years and a 2022 Mustang GT(ESS supercharged) for the last 3.5 years. Recently I was in a collision and it looks like it is going to be a total loss. So, change of direction. The kids are in middle school and I think that I'm going to find a well maintained Denali so I can buy a nice used boat to hang out with the kids more. Neither of them nor the wife enjoy the car anyway. I've been trying to do a ton of research over the last few days. Is there is any main issues to worry about other than air-conditioning condenser issues, headlight and tail light issues and such?
Welcome to the Forum from NH.
I will defer to the Forum members who own a Denali in the model years that you re looking at.
BigBoyZ71
Calgary, AB
As a first time GM owner only recently, I've run into a few issues (personally and via research). Not specific to the denali, but the full 15-20 family of tahoes/suburbans . Some issues listed below;
- Torque converter issues and the potential to destroy the transmission internals
- AFM/DOD and associated lifter issues
- fuel line rubbing on the top side of the fuel tank, causing leaks
- rear window defroster tabs delaminating from the window (very easy fix)
- if you're coming from a mustang, you'll likely want to look at a tuner to adjust throttle response and transmission settings, I found both to be lacking with the factory settings
However, that is all to say that these are great trucks with manageable issues if you're aware of them.
Bob Lob Law
Bob Lob Law
A tune will be happening within a week or so of purchase. On that note. I've been away from GM for 15 years or so. Who are a few of the top tuners for these? Any use an RTD? Thanks for the replies! I hadn't heard of the fuel line issue. None of the known issues scare me off any. I'll do most of my own work, and what I'm not comfortable with my best friend is a lifelong mechanic and owns a shop.
If you acquire a 2019 truck or earlier, BlackBear Performance is a solid tuning vendor that is used by many of the folks on this Forum. It is a custom tune for your truck, meeting your specific tune requirements, and it is performed remotely by email at a cost of ~$700. You get an AutoCal device as part of the cost of the purchase, which allows you to collect the live data that BlackBear Performance requires to assess your current truck operation, and then they assemble a custom tune for you. You use the Autocal device to install a tune file for the ECM and a tune file for the TCM. You can request tune updates for a nominal fee, if any future mods that you do to your truck requires a tune adjustment. You can also revert to the original GM tune at any time using the AutoCal device, if circumstances require you to do so.
Bob Lob Law
Bob Lob Law
Yeah, that's how it works in the mustang world as well. That's why I asked about the RTD as I have one. LOL $700 isn't bad if it includes the Autocal device. Thanks for the info about BlackBear Performance!
Hello,
I would just be sure it has been maintained and check every single function to be sure it works properly before you sign anything, that way you can get anything fixed on their dime before you own it.
with all the little bells & whistles there is bound to be something that no longer works, just how the dice roll
that means test every button and gizmo, even ones you might never use, including the power seats, power fold, sunroof, rear hatch/glass buttons and controls rear wiper, so on and so forth.
hud, cruise of which you may or may not be aware there is 2 different types of cruise (normal & auto), some may only have one or the other and some may have the option for both
then you have your blind spot stuff, rear lcd screens
air shocks in the rear, those blow out
CHECK EVERYTHING.
then your going to want to service all the fluids anyway, plugs, wires, perhaps other things depending on the mileage.
get your self a decent scanner if you plan on DIY
I plan on checking everything I can. I have access to a dealer level obd scanner and will take it with when checking it out.
If they offer a warranty option I would take it, something as simple as a oil leak can be a real b$tch on these, there is 2 oil pan seals basically.
injectors are under the intake and there is a high pressure fuel line that can get bent easily.
a warranty is a gamble but it can pay off well sometimes. just don't take the cheapest tier that's just a money grab and doesn't cover sh&t
mid (powertrain) or top tier are your best options
Bob Lob Law
Bob Lob Law
How necessary is it to spend the extra time and money pulling the TCM and having it tuned when getting a tune from say Blackbear Performance? Will/does it help the life of the TC?
thefrey
Others will be able to chime in more than me, but from my understanding, with the AFM/DOD it can be a little rough transitioning from v8 to v4 so they put torque converter slip in to help it be smoother. but I think long term if you are disabling or removing AFM/DOD then it makes sense to tune the TCM.
My tuner did a tune on my transmission to change torque converter slip to help the TC last longer. Not 1000% sure why but I think the reasons mentioned above were a piece of the puzzle.
Bob Lob Law
Bob Lob Law
That's what I was thinking. For the extra little $$ and a week or so down it'll be worth it I hope in the long run.
Maybe, I'm not understanding this conversation. With a BlackBear tune, you do not pull the TCM. Your tune is accomplished electronically through the OBDII port.
randeez
south florida
i dont think t87/t87a tcm needs to be sent in for unlock service anymore, can all be done thru the obd2 port
(with hptuners)
Bob Lob Law
Bob Lob Law
According to Blackbear Performance the '17+ need the TCM sent to them for unlock.
All 2014+ 6.2L engines require 91+ octane for optimal performance and efficiency due to compression ratio.
Transmission tuning on 2017-2020 8- and 10-Speed Transmissions is available. It requires the TCM to be mailed to us to be unlocked for an additional $175. Contact us for more details.
*Due to variability in turbocharger systems, they must be evaluated by our tuner prior to committing to any services. Additional tuning service/hardware may be required.​
I didn't know that for the '17+ motors, though I did know that GM adpoted a new module security system.
Well, at least these newer transmissions have the TCM located external to the transmission's inside casing.
I learn something new every day.
Bob Lob Law
Bob Lob Law
Finally, insurance is moving forward with totaling my car. They are giving me the rest of the week to get my supercharger, wheels, and other accessories off of the car. Should be buying a Yukon in the next couple of weeks!!
Anyone on here have a '18-'23 Mustang looking for parts? LOL
Bob Lob Law
Bob Lob Law
Update.....
Picked up a SUPER clean 2019 Denali white on tan. 69,000 miles and I don't believe the back seats have ever been used before. The Bose leaves me wanting way more, so a system is in order within the next year. Other than that, I'm super happy with it so far.
Chevy1234
