Linda's 2002 TrailBlazer with 80k miles
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Slight introduction here. I am no longer using GMT Nation for Linda's GMT360 2002 Chevy TrailBlazer information processes. The Canadian moderator did not like my 9/11 remembrance post and said it was offensive. My account was threatened and he deleted the post. I asked why and did not back down and pointed out that the post mentioned no politics or politicians names. He did not like that logic and closed my forum account. At least they are issuing a $60 Supporting Member refund.
I looked for other GMT360 Forums and found one labeled Blazer Forum and was very difficult to set up account and post notifications were crazy. I found this section here and so I will post about Linda's T/B here. Plus, at Blazer Forum, no matter how I tried to set up an Avatar pic, it would only post it, turned 90 degrees to the left.
If anyone has any questions about the GMT360 platform, shoot them my way and I will try to help. I have done some work on hers and it is a fantastic vehicle.
strutaeng
Dallas, Texas
The HELL with THAT Canadian moderator!
Welcome to the TYF Trailblazer! Those Atlas engines are incredibly durable. My nephew's wife has one and I believe it's got 300k+ now. Original everything! Runs smooth and fuel efficient. Just tires and brakes is what they've done.
OR VietVet
OR VietVet
Willamette Valley
I had done some research before we bought her TB. Water pumps known for leakage and it was leaking when I bought it. The transfer case module, in the very early models, was known for failing. Linda's did fail and I replaced with no problems, with help from LS Logistics at ebay. I had to replace the VVT solenoid. It had a mixture of ignition coils and did develop a misfire and I did all new plugs and GM coils. Recently had a parasitic draw that my Power Probe draw tool helped with and was related to the two power port/cig lighter sockets and was fixed and the usual ignition switch problem that has been fixed. The rest was oil changes, transfer case and diff fluids changed and transmission fluid/filter changed. Brake fluid flush and cooling system refreshed when did the water pump and new thermostat was done at same time.
So, some repairs and some maintenance and many worry free miles on the 4.2 engine. Very reliable, IMO.
JoeBlobs
Senior Member
NJ
Do you have the PowerProbe3? I always thought the extra features were neat, but never ended up using them. Seems like it was effective for you.
OR VietVet
OR VietVet
Willamette Valley
I used the PPDRAW tool. Plugs in at DLC and assumes battery role and shows draw amounts. You unhook battery negative cable, or both cables, and never lose connection.
Marky Dissod
The moderator of GMT Nation did not like my 9/11 remembrance post and said it was offensive. My account was threatened and he deleted the post.
Regardless of his nationality (I don't blame nationalities or demographics, I blame individuals) he's wrong at least 4x, and I don't even know the whole story yet.
What's his name? (Terrence? Phillip?)
the 18th letter
Northern New Jersey
My next door neighbor has one of these in the same color. I assume they are tough vehicles because he abuses that thing but I hear him going to work at 430am everyday. I don’t think it’s ever been washed and not sure how he sees out the back window but it’s reliable enough that I no longer set an alarm clock the past 3 years. If he ever fixes the exhaust I’d probably be late for work :D
OR VietVet
OR VietVet
Willamette Valley
Screen name is "Mooseman". I also did not blame his Canadian nationality and never mentioned it. I just stood my ground and stated there was no politics or politicians names ever said/mentioned. My post here was copied and pasted.
OR VietVet
OR VietVet
Willamette Valley
The 4.2 engine has a distinct sound. I heard it and then asked some members at GMT Nation about it and they all said, you mean the "sewing machine sound"?
It sounds like a very powerful sewing machine sound.
The only design that was new to me was this:
If I need to do the oil pan for any reason, you deal with the axles traveling thru the oil pan and all it takes to remove all that for oil pan access.
Fless
Moderator
People's Republic of Colorado
Similar to BMW xDrive.
Marky Dissod
The Atlas 6inline was a good idea, reasonably well executed, but I remember it having at least one major flaw that if allowed to occur usually totals out the engine.
Atlas 5inline & 4inlines were GM's attempts at amortizing costs, they were not as successful because they are not as good.
Had the Atlas 6inline more closely resembled the Chevy Small Block V6 in terms of long-term maintenance and repairability,
GM might've considered it to succeed the LU3 4.3L V6 as it would've been cheaper to make.
OR VietVet
OR VietVet
Willamette Valley
Well, what is/was the major flaw.
Gecp9728
