Just bought a new 2026 Tahoe Z71 6.2 what do I do?
MRPRO
I feel really stupid. I’m usually very diligent and dot every I cross every T before I purchase a vehicle. New or used. I’ve been looking at getting back into a Tahoe for a few months now. Mostly looking at loaded 5.3 Z71s. Sale prices in my area have been very close to MSRP. Maybe 4% below at best. Was doing a random search about a week ago and came across what seemed like a phenomenal deal on a Tahoe that was equipped the way I wanted. Has the 6.2. I’m thinking more power even better. I’ve had the 6.2 in the past no issues. So I strike a deal and now own it. Today I started looking into ways to make it theft proof and to eliminate the DFM as that has been what I had heard were big issues leading to problems down the road and come across all the engine failure videos, posts, recalls investigations etc. and am very concerned and second guessing my purchase. Don’t know how I missed this in my research. I was totally focused on getting a 5.3 thinking I wouldn’t be able to afford a 6.2 due to budget so maybe that’s why I missed it. Now I’m just distraught and wonder if there’s anything I can do to prevent an engine failure that seems inevitable. Thoughts?
ReaperHWK
My 2026 6.2L has been great so far. 14k miles and doesn’t burn a drop of oil between changes. . Just get a catch can, magnetic drain plug, and a range DFM disable and motor on.
You have a 60k miles warranty. If you’re really worried about it get an oil analysis at 10k miles. If any abnormal bearing wear shows up buy an extended warranty to 100k miles.
2025 and 2026 are excluded from the recall and supposedly have a fixed crankshaft bearing tolerances. Yes there are reported failures but it’s a small sample set. I think it was about 500 failures reported out of the 2025 and 2026 years. Quick google search says in the neighborhood of 200k engines made those years.
LEsoftballdad
Suffolk County, NY
I hate to say it, but unless you're willing to take an enormous hit on a trade or sale, you're going to be stuck with a potential nightmare. Good luck.
M
MRPRO
Would you have any links handy for catch can, dfm disable, drain plug? What’s a motor on?
As I read more, the 2025-26s have also been included in the recently extended NHTSA investigation into post 24 failures since the engines still seem to fail after the recall which included oil upgrades to 0W40 and/or engine replacement and only to fail again.
What about oil change to 5W30?
LEsoftballdad
Suffolk County, NY
I suggest reading this thread, if you haven't done so already.
M
MRPRO
Options I guess are to trade for a 5.3 version of the same vehicle if I can find one, trade for an alternative, take my chances, or sale at a loss?
jfoj
J&L Catch Can, Range Technology RA007 unless you want the bluetooth version for vehicle diagnostics, Votex M12x1.75 drain plug and M12 crush washers on Amazon. Suggest you consider FilterMags SS300PR, you may find on Amazon. Consider changing the oil at 500 miles, then consider if you want to move to 5W30 or 0W40. Save every oil filter, start with a spotless drain pan before each oil change and inspect what is in the bottom of the drain pan once you carefully pour it off. Consider obtaining about a baby food jar size oil for a sample at each oil change, label it and you can always send it for Analysis later, the only thing that may change is the fuel dilution in case the sample is not sealed well, but you are mainly looking at wear metals. Consider changing the oil at 50% of the OLM.
Doing all of this may not be a 100% guarantee that you will be safe, but you do what you can to keep the vehicle alive as long as possible.
Good luck, I hope you have good luck with your new purchase, unfortunately you will probably read about situation!
The vehicle in your signature was the best vehicle you probably ever had! My 2005 Yukon Denali has 281,000 and is current my daily because my 2024 has been sitting for 10 weeks.
M
MRPRO
I too have a 2005 Denali. Rusty but not obvious. It’s my 3rd one. Last one got stolen. Rusty one almost got stolen a couple months ago. 150K miles. Great vehicles. Also interested in theft prevention. Thieves are just watching and waiting where I live to ****** their next GM truck or suv
jfoj
You must live in a tough area!
Best way to disable a vehicle IMHO is via the fuel pump fuse. Set up some way to hide 1 or 2 switches to tie together in series and loop the fuel pump fuse in series. Toggles that are DPDT center off that have 2 positions and wire them so they have to be in a specific position. Possibly put under console of you have a sliding electric console. Or put on in the glove box and one somewhere else that means you have to find both and put in the correct position.
blanchard7684
Senior Member
Not much you can do at this point. Stay optimistic but realistic. I would hope the statistics would work in your favor that your version of the 6.2 is ok. These things don't have a 100% failure rate with any failure mode.
With that said...I would do very frequent oil analysis and the magnetic drain plug. Check the plug before every long road trip. This will prevent you from getting stranded.
Do frequent oil changes well before the oil life monitor says to. This isn't just for the bearings but also the needle rollers in the lifters. Clean oil also keeps the lifters from sticking during a DFM switching event; and keeps the low tension piston rings from sticking.
Get a DFM disabler either from range or carbyte. Carbyte is plug and play but only activates above 40 mph.
For short trips and errand runs, learn habit of putting unit in L9. Or get the range system.
Get a good catch can. They work well at minimizing the goo build up on back of valves.
Start planning a valvebody upgrade and also a transmission pan upgrade.
Oil type? JFOJ's recent thread really indicates that oil type will not stop this failure. There is "something else going on".
If you stick with 0W20 you reduce risk of warranty drama. Not a trivial matter.
0w40 is the actual ideal oil type for this engine. It is spec'd for other L87s in other applications like Camaro. It has a dexos cert. You will likely not have any warranty drama over this. Remember they have to prove the oil type is the cause of any issue. That is exceedingly hard for someone to do given GM's remedy for many L87s was to use 0w40.
For oil filters use OEM branded (PF63) or better.
blanchard7684
Senior Member
For theft protection you can search for an OBD II port lock. Make sure it is specific to your vehicle. There are new steering wheel locks that use the seatbelt mechanism that are pretty slick. I used both.
PG01
Up here to the right
Dont take this the wrong way but i would park it somewhere, leave the keys in it and walk away ….
LEsoftballdad
Suffolk County, NY
You could always go with a newer build date with the Duramax engine, but even they have issues with thrust bearing failures. That issue seems to be limited to certain build dates, but you just don't know for sure. The 5.3 still has a lifter failure issue, and, as Blanchard said, you might still have an issue with the transmission's valve body. Next Gen sells a great upgrade kit for all GM and Ford 10-speed transmissions, but the problem is that you shouldn't have to do that. You paid a lot of money for the vehicle. It's not outrageous to expect them to last without having to bring them in for all kinds of warranty repairs.
I wish I had a simpler solution, but the reality is that between government regs and corporate penny-pinching, the options for super-reliable vehicles seem limited these days.
Scarey
Sounds like you bought it a week ago. Try asking the dealer to take it back minus mileage. I think it’s criminal that they are still selling these with the history. Buyer beware but I think there is a certain responsibility of the seller. At least you will have tried, who knows it could strengthen any fight you could have with gm if you have a failure later.
Jetskier77
The price on those filter mags is ridiculous. it may be worth it as an insurance policy... or you could install a higher quality filter, one that catches debris to a lower micron level.
thatboy_eddie
