Jacking a 2017 Tahoe
k1970
Oman
Hi,
Is this a correct jacking point?
drakon543
i dont recommend using the shock mount as they aren't designed to support the weight of the vehicle only the functions of the shock. ive seen people buckle shock mounts doing that.
Tiredmechanic23
As the image above shoes there is a pad welded to the axle to use as a lift point for either side. You can lift at the center if wanted to pick the entire rear up.
