Issue with signal fuse blowing when shifting into reverse
Sheltonlutz
I have a 99 tahoe with a issue of blowing the signal light fuse everytime I shift into reverse I changed out the rear light boards and bulbs in hopes that may fix it , it worked good for apx 2 weeks then issue came back ,what other things could be causing this issue ?
S
Sheltonlutz
Did you try it with the taillights disconnected? That would eliminate them as a source of the problem. I'd look at the shift linkage and see if any wires are rubbing.
Ill give that a try and see what happens hopefully it at least narrows it down
RobK
