Issue identifying a replacement part.
TEXCHEVY
Italy
Good morning everyone, I have a leak coming from this hose or fitting. I wasn’t able to find the replacement part number. Does anyone know exactly what it is? I was able to take these pictures. It’s located low down on the driver’s side, behind the fender liner. Also, I can't figure out what that cap-like thing (at least I think it's a cap!) on top of it is. Steering line?? I haven't found parts on rockauto that look like
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
What is actually leaking out of it? Oil? Antifreeze? Only thing with a cap I know of is an axle vent.
@915_Tahoe can look up parts but you need to tell us what that is. Is it an oil cooler line? Where does it run to and from?
TEXCHEVY
TEXCHEVY
Italy
It’s nighttime here now, but I went back outside to take another look. It appears that the hose is coming from the power steering fluid cooler. There’s only a small amount of fluid on the ground, and it looks like it’s the same color as the fluid in the power steering reservoir.
TEXCHEVY
TEXCHEVY
Italy
Do you have hydroboost brake assist? Or vacuum? Could easily be a power steering line for the hydroboost. Follow it to see if it goes up to the unit behind the master cylinder.
Hello!. Yes! hydroboost!. I followed the hose; it ends up under the power steering fluid reservoir.
Chevy1234
