"Integrated" Subwoofer Options
Tonyv__
Bucks county PA
Didn't you say the driver came from a ported box? The difference might be worth investigating.
joe
Well initially yes, I bought the driver intentionally for a ported enclosure. That box was much larger and sounded great for what I wanted. I’m not really willing to give up the space needed for a ported box now.
homesick
The Best Me I Can Be
FWIW, I got this from Perplexity...
A ported (vented) 10" woofer's box generally needs to be larger than a sealed 10" woofer's box. This is because ported enclosures require more internal volume to achieve deeper bass extension and accommodate the port itself, which helps reinforce low-frequency output. In contrast, sealed boxes use the air inside as a spring to control the woofer's movement and can be built much smaller for the same woofer size.
For example, a typical sealed enclosure for a 10" woofer might have external dimensions around 12"x12"x12", while a ported (bass-reflex) enclosure for the same woofer could require dimensions closer to 16"x16"x16".
joe
L87Victim
