Shibbershabber
- Joined
- Sep 9, 2017
- Posts
- 129
- Reaction score
- 37
Having a long block built for my 94 pickup...
Trying to get as much of the related parts together as possible... am I missing anything?
Intake & exhaust gaskets
distributor
water pump
clutch
valve cover gaskets
throttle body gasket
thermostat gasket
oil & coolant
motor mounts
oil cooler lines
serpentine belt
Oil pump and oil pan installed by builder...
Im thinking a gasket for the oil filter adapter... found this, I have a 4x4 with the angled adapter, are the gaskets the same?
anything else needed to make the swap? Recommend anything else to be replaced while the engine is out?
THanks!
distributor
water pump
clutch
valve cover gaskets
thermostat gasket
oil & coolant
motor mounts
oil cooler lines
serpentine belt
THanks!
