Install a backup camera in a 2007 yukon
Albertayukon
If I wanted to install a BUC im my 2007 Yukon (I have a nav screen) what do I need. I assume the camera itself and a harness. If thats all whats the best way to run the harness?
Ted
Ponchonutty
New Washington, Ohio
What stereo do you have? Is it a factory GM one? If so, you will need the back up harness pigtail that goes into the radio. The camera will be aftermarket??? If so, they just have standard 12v, ground, and RCA that you will have to adapt to the radio you have in there. It's not an super hard thing to do but if you don't do it all the time, you may want to consider the system inside the rearview mirror instead. It will be much easier to install
4pfTeejayiee
