I feel like an idiot......
dropmech
Puddle Pirate
Coral Springs
I build jet engines for a living, but I can't figure out step one to changing out the spark plugs on my 06. How do i get those stupid wires off of the plugs. Whats with that metal casing over the plug? does it pull out? Does the wire pull out of the metal casing first??? HELP ME!!!!!!!!!
Max
Mile High
Denver
Lol just twist them close to the plug as possible, the metal cans are heat shields due to the close proximity of the exhaust manifolds. My wires didn't want to come off easily but just give them a twist and they should pull right off. Have fun with the passenger rear plug too, angle and shorty extension is key for doing plugs in these things :cheers:
dropmech
dropmech
Puddle Pirate
Coral Springs
Thanks Max! I have the ac delco iridiums. I believe they are supposed to be .040?
---------- Post added at 04:01 PM ---------- Previous post was at 03:57 PM ----------
I think I need a new wire. The metal part that attaches to the plug just pulled out and stuck to the plug. Can I put that back on the wire?
Max
Mile High
Denver
Yes you can put it back on the wire, don't adjust the gap on the iridium plugs or you may damage the electrode...that gap is fine btw some standard plugs just come with .060 or higher which isn't optimal for these trucks.
Max
Mile High
Denver
No worries dude, best of luck don't forget to dial up a bit of anti-seize on the threads of the new plugs.
Brick
Boca Raton, FL
Changing plugs is always fun, that's why the last time i did it I just ordered new wires, because I new I would bust em up, and I did! The set up sucks on these trucks, the back ones are nearly impossible to get too!
Bilma0911
