How to hardwire dash cam
mo2058130
This thing is kicking my butt. Ground is to a bolt to frame and power is on the fuse tap to a fuse. The camera is still not getting power. Tested the fuse with a multimeter, 12v with acc key position. Not sure what I’m missing. Any ideas? Thanks all.
2005 GMC Yukon XL
wjburken
Eastern Iowa
2005 GMC Yukon XL
Do you have a picture of how you’re tapping into the fuse block or at least a hint as to which fuse you are tapping into?
tap into the power mirror harness, easy peasy, at any rate if you don't want to use the power mirror then use the panel down at the drivers side lower kick plate
M
mo2058130
Thanks all for the reply. The fuse has 12v but apparently a hardwire kit is needed in order for the camera to run properly. The kit includes a voltage detector so it doesn’t drain ur batt. I’m guessing that the cam will not run without this kit.
Also, I’m sure I’m better off using it since I don’t want a dead battery either, lol.
I’ll follow up after I receive and install the kit.
2005 GMC Yukon XL
2005 GMC Yukon XL
this why I stated to use the harness on the mirror, it only has power when the key is on, no way for it to drain anything
I have mine connected to a 12v to 5v usb adapter wired up down at the drivers kickpanel, then I have my radar detector wired to the mirror harness, both come on automatically when the key is turned on and shut off when the key is off
Wylie_Tahoe
2005 GMC Yukon XL
There may be more to that "kit", but connecting to a switched IGN 12V means the camera is only on when ignition switch is on. Maybe the camera is like some GPS, they run on 5V, so you need a resister.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
2005 GMC Yukon XL
Yes I am running the Rexing cam and I had the same issue. You cant bypass the doohickey thing in the harness. I cut it out by accident when I went to install in a different location. I had to order a new harness and it worked perfectly.
clandr1
Dallas/Fort Worth, Texas
JohanZ
