Help ASAP with amp install
Buckeyechad
Hello all !!!
I am in need of help!! I have my center console removed from 2012 yukon (huge PITA!!').
Installing two amps. One for new door speakers and one for subs.
I want to maintain factory amp and sub as well as install the new amp for additional subs in rear. Can I tie into wires going into current sub or amp to get signal for additional amp in rear ..... Not power only sound ( and remote turn on???)))
If so,... Will it mess up sound in any fashion?!!!
Thank you!!
08grey
Get the bass from the center I think it's light blue and green. And get the miss and highs from the center channel on the dash. No effect on your current amp setup.
B
Buckeyechad
From center??? Not quite sure what u mean. I am getting front and rears from existing wires under center console. Are those the wires u are tdlkking about???
08grey
I take it you don't have the center channel in the top of the dash then.
Yes you can take it from the front and rear but the signal at the wire is not full range. Many of us have has issues with the Bose system getting a good mid and high signal. I have a 08 and have had it upgraded to the 12 radio. When I did so the center channel was full range.
B
Buckeyechad
Anyone know where I can find wiring diagram for 12 yukon. Have Ctr console off and amp uncovered. Would really like to know what wires are what. Which to tie into for door speakers??? Which ones to tie into for new amp and still keep current amp/sub??! What harnesses are going into factory sub (3 of them)??
08grey
Pm me your email. I'll send it to you.
B
Buckeyechad
Got wiring diagram if anyone else needs
---------- Post added at 07:18 PM ---------- Previous post was at 07:17 PM ----------
Got it
---------- Post added at 07:18 PM ---------- Previous post was at 07:18 PM ----------
Got it
kylesimmons
