Looking for some info if a trans out of a 2008 tahoe work in my 2009 looking for a budget build recently picked up a 2009 tahoe with trans issues still has 1st and 2nd but slips in all other gears even reverse. Previous owner broke a line on it and was run low on fluid pulled pan and inspected it was a bunch of small shaving in pan. Has a code set in the tcm. For p0776 code
No, the 2008 has a 4-speed transmission and yours has a 6-speed transmission.
If the transmission has been filled to the correct level, with the correct fluid, and checked after shifting through all the gears while sitting still, it may resolve itself. Cold check fluid temperature is between 80-90 degrees on the dipstick. This gets you into the ballpark. Hot check is 158-200 degrees and is most accurate.
If that doesn't solve the problem, the likely culprit is the 3-5-R regulator valve sticking. This can be repaired from the bottom of the transmission, without removing it, if memory serves. Nick will correct me if I'm mistaken.
That code, P0776 could also be related to other problems which would require removal of the transmission from the vehicle and partial or complete disassembly depending on the issue.
That code limits the transmission to 2nd or 4th gear depending on what the speed sensor sees. Less than or greater than 1,400 rpms.
A GM remanufactured unit is about $5-6K installed and comes with a 3 year, 100K mile warranty. Live near Vegas? That's where Nick's shop is located.
